Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-02-2018, 12:48 PM   #1
Redraider
which harness??
Hi guys,
I have a '51 5 window that I will be doing a modern drive train and suspension on, but I don't have a clue as to which new harness I should use! Just how many "circuits" do I need? Power windows and locks are only a remote possibility.
Thank you for any light you can shine on this
Redraider
Redraider is offline   Reply With Quote
Old 12-02-2018, 01:09 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: which harness??
Originally Posted by Redraider View Post
Hi guys,
Redraider
It really just depends on the circuits you want to add.
As far as the motor and transmission goes depending on what you are buying. If your doing a LS swap then by a stand alone harness and your good, you then use what's in the truck now also. The stand alone will run the motor & transmission. If you want to monitor the motor stuff buy a Scan gauage 2 are a simaliar product.
This link has a bunch of info.
http://67-72chevytrucks.com/vboard/f...ysprune=&f=206
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-02-2018, 06:01 PM   #3
NorCalGal
NorCalGal's Avatar
Re: which harness??
I recommend the American auto wire kit.
Jan's 53
NorCalGal is offline   Reply With Quote
