Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-06-2018, 11:55 AM   #1
vin63
It's Better With Nitro
vin63's Avatar
LED 4-Post Lift Lights
Picked this up at SEMA this year. Works a lot better than expected.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-06-2018, 11:48 PM   #2
Advanced Design
Advanced Design's Avatar
Re: LED 4-Post Lift Lights
Good idea. Is it flexible? Something like that would be handy many places working on a vehicle.
Advanced Design is offline   Reply With Quote
Old 12-07-2018, 11:07 AM   #3
vin63
vin63's Avatar
Yes, it's 3/4 circle poly vinyl tube of LED lights that has a series of magnets on the back so it sits at a 45 degree angle in the corner of the runner, so it shines the light up and toward the center. It comes coiled in a box, so it's very flexible.
Old 12-23-2018, 03:33 PM   #4
wahl4m
have any ides what brand the lites are ? 7 price ?? thanks mike
wahl4m is offline   Reply With Quote
Old 12-27-2018, 02:44 PM   #5
vin63
vin63's Avatar
I think they were marketed as LiftLyte. They are 14-feet long on each side with magnet attachments, so they can be moved around a bit. Not sure what the retail is, but as a reseller, my WD price was $225 at the SEMA show. There were other versions on display.
Old 12-27-2018, 06:17 PM   #6
Advanced Design
Thanks vin63. I was looking at various flexible led lights on Amazon to see if I could put something similar together. A 3’ section would be handy for under dash work if it was bright enough. What I couldn’t tell was how bright they were so need to do some trial and error.
Old 12-28-2018, 12:41 PM   #7
vin63
vin63's Avatar
That's a good idea as I use a portable, battery-powered LED drop/work light for tight spaces and it is really bright without draining the batteries so quickly. I'll take a lit and unlit pic, so you can see the how bright it is under the chassis later today.
Old 12-28-2018, 08:00 PM   #8
vin63
vin63's Avatar
Here's the comparison between unlit and lit...
Old 12-28-2018, 09:58 PM   #9
Advanced Design
Thanks Vin...Holy wow, that makes a nice light! What do you have up on the lift?
Old 12-28-2018, 10:29 PM   #10
vin63
vin63's Avatar
Trying to finish my '63 C10 project...
Old 12-29-2018, 01:01 AM   #11
Advanced Design
Sweet!
Old 12-29-2018, 04:36 PM   #12
The Rocknrod
Moderator
The Rocknrod's Avatar
Vin is yours bagged in the front?
Old 12-29-2018, 06:17 PM   #13
vin63
vin63's Avatar
Yes, air springs at all 4 corners.
