Old 12-12-2018, 08:38 PM   #1
Android04
Android04's Avatar
3 Speed Transmission
Guys I need some help! My trans blew apart and I found another one local. The guy is saying it is out of an Impala; are they the same as our trucks?
1965 327sbc 3 on the tree swb truck, trans is a 3 speed with a 4 bolt side cover. The one from the impala is identical from the pictures.
Thanks so much
Android04 is offline   Reply With Quote
Old 12-13-2018, 12:10 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: 3 Speed Transmission
The case will bolt to the bell housing just fine, but make sure your tail shaft is the same length. Some 4 bolts have a long tail shaft, others have a shorter tail shaft. Since they are both 4 bolt covers, you can swap side covers to retain the truck shift forks
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 12-13-2018, 04:50 AM   #3
Android04
Android04's Avatar
Perfect, thank you very much
Old 12-13-2018, 10:52 AM   #4
MikeN
MikeN's Avatar
The diameter of the front bearing retainer may be smaller, in which case it will bolt to your bellhousing, but won't be indexed properly. You might want to check that - bearing retainer outside diameter should match the inside diameter of the round hole at rear of your bellhousing. You can probably swap over the bearing retainer from your truck transmission if they don't match.
MikeN is offline   Reply With Quote
Old 12-13-2018, 11:22 AM   #5
Android04
Android04's Avatar
Thanks for the heads up. I will check that as well.
Old 12-13-2018, 02:13 PM   #6
andyh1956
Be sure to ask the seller of the Impala trans if it has EVER jumped third gear.
At least you'll be able to Hear him say it even if it does...
andyh1956 is offline   Reply With Quote
Old 12-16-2018, 06:46 PM   #7
factorystock
factorystock's Avatar
Great time to upgrade to a full synchro 3 speed.
factorystock is offline   Reply With Quote
Old 12-17-2018, 12:04 PM   #8
andyh1956
Times 12!
After scrounging the country side over for trans / parts to fix all the crashboxes I destroyed in high school I can't see how's there any left out there at all!
