Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-23-2017, 06:32 PM   #1
MASTERBrian
Plugging firewall holes
I have about 20 holes of various sizes in my firewall. I've looked at two local parts stores, a Lowes, and an Ace Hardware for rubber grommets/hole plugs. I know they make what I want/need as I am sure I've purchased them years ago for my cars. Amazon seems to be my best bet for buying a bulk and hope that what I get might work. I'm curious if there are any other great ideas out there.
I've thought of welding a few of them shut, I've also seen where another member uses JB Weld and coins to plug holes. Problem is I'm not sure if I'll want any of those for later use, when running additional wiring.
There are also two identical holes right where the tranny tunnel starts going back, they are about 5/8" and the metal is flared out....any idea what these are? I can post pic later if need be.
MASTERBrian is offline   Reply With Quote
Old 02-23-2017, 07:45 PM   #2
James the III
Re: Plugging firewall holes
http://www.mcmaster.com
granger (sp?)
http://www.boltdepot.com/catalog.asp...FRCe4AodmlYAnQ
James the III is offline   Reply With Quote
Old 02-23-2017, 08:05 PM   #3
tinydb84
tinydb84's Avatar
Why not weld them up? You can always drill a new one later.
David
Instagram: myfabguy
Old 02-24-2017, 02:43 PM   #4
bs46488
I bought a bunch of rubber plugs off of ebay in various sizes.
I had a bunch of holes in my floor from the previous owner. I didn't want to weld them all up.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 02-25-2017, 10:07 AM   #5
blazer2007
weld a bolt to a piece of metal of the size you want with a little rubber gasket and then you could take it out,could paint the piece matching color
blazer2007 is offline   Reply With Quote
