Old 11-07-2017, 01:54 AM   #1
Ryan Hubbard
Holley Terminator EFI Install
I installed the Holley Terminator TBI EFI system in my 71 C20 pickup a couple weeks ago. I also have it controlling my 4L80E transmission. Here is the spec for my truck:
Engine
350 4 bolt main bored .030 over
Edelbrock Performer RPM Heads
8.5:1 CR
Manguson Eaton Rotor Supercharger (12 PSI Pulleys)
Transmission:
4L80E
Rear Axle:
Dana 60 with 3.55 gears and Detroit Locker
The install went pretty well, I had a TCI transmission controller installed in the truck so I just reused the hole in the fire wall for the Terminator wiring and mounted the computer on the glove box door. ( I have a billet aluminum glove box door) I also used the Holley Fuel pump kit with the filters, fuel line and fittings.
I also installed a small cap HEI electronic distributor so that the Terminator system could control the timing for the engine. I am still using my MSD 6AL ignition box too.
Since I am running a roots blower, I had to change out the MAP sensor to one that referenced the manifold vacuum/pressure after the blower. I just cut the plug of the wiring harness and connected a new plug and some longer wires and told the ecu that I had a 3 bar Map sensor.
Once I got the system installed, I followed the instructions and was able to set the initial timing and got the engine started and running. Once I got the engine running it took a little "tweeking" to get everything dialed in.
After the initial starts and tweeking, I started driving the truck and noticed a big improvement in drivability. I have now put over 1000 miles on the truck with this system on it and towed my other 71 K20 pickup over 600 miles and was able to get 9 mpg towing while still maintaining 75-80 mph on the interstate. (Before anyone says anything, my truck has 4 wheel disk brakes and trailer brakes and I was following the posted speed limits). I had done a lot of work on the carb for this truck and it was a well tuned carb but still not as nice as this system. I am driving another 700 miles tomorrow without the trailer or truck and I will see how that drive goes. But I was getting around 13.5 mpg with out the trailer. I am going to tweek the tune a little on the trip tomorrow and see if I can get a little better mpg. Not bad for a truck that has 550 Hp and over 500 LbFt of torque.
Ryan Hubbard is offline   Reply With Quote
Old 11-08-2017, 08:26 PM   #2
Husker
Husker's Avatar
Re: Holley Terminator EFI Install
I want to Try one of these Kits on my Jeep CJ5 304 v8
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 11-10-2017, 11:02 PM   #3
YoungPup1977
YoungPup1977's Avatar
so I was wondering, the cost of this unit worth it ? if cost was a factor....
YoungPup1977 is offline   Reply With Quote
Old 11-11-2017, 12:48 PM   #4
B. W.
B. W.'s Avatar
Hey, would you mind posting some pics? I am thinking about a similar setup.
B. W. is offline   Reply With Quote
Old 11-18-2017, 01:44 AM   #5
Ryan Hubbard
The cost of this unit was a small factor but I was leaning towards the FI Tech system but they did not have a way to have a TPS output to a transmission controller. I was replacing my transmission controller because I was tired of dealing with the TCI controller. Once you look at the cost of a good controller and the fuel injection system, I decided it would be nice to control everything from one connection to a laptop.
I now have over 3,000 miles on this system and I couldn't be happier with the performance. I have tuned out all the "issues" which were just small tip in issues with the unit going lean. I am now tuning for economy.
Old 02-04-2018, 02:31 AM   #6
funkatation
I just received my terminator kit. Nice to see you have had good luck. I had a fitech and PCS simple shift. I had to use the carb tps sensor and heard people using a y split to tap into it, but since everything was pulled, I wanted to clean up the wiring and have one system. Almost went with the msd atomic, but still a couple of boxes. Looking forward to hooking them up to my Dakota digital gauges to since they talk to each other.
My 4l80e has a shift kit in it and always shifted really hard from 1-2 with the old controller. You notice any difference between the tci and the Holley as far as the trans controller goes?
funkatation is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
