Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-06-2018, 01:20 PM   #1
SJLenz1340
Switching ground?
In many automotive schematics that I have seen the ground is switched more often than the power supply. Is this the preferred method with DC power? And does it matter if switching a solenoid?
I am not a stranger to electrical circuits and wiring strategies, just not involved in DC that often. In my world low voltage control circuits often switch a “common” wire to minimize arching and mitigate inrush currents.
Thanks for any input!
Regards
Steve
SJLenz1340 is offline   Reply With Quote
Old 08-06-2018, 02:56 PM   #2
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: Switching ground?
It is done not because it's preferable, but because it avoids running an extra wire in the circuit.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 08-06-2018, 08:59 PM   #3
dmjlambert
dmjlambert's Avatar
Yes. An example is in a door jamb switch for courtesy light. If you were switching the 12V + side, you would have to run that 12V wire over there to the door jamb switch and also run the return wire from the switch to whatever you are switching on. Switches that connect to ground can be daisy-chained if desired and with one wire, switch the ground side of a device. Another example is the wiper/washer switch that grounds different combinations of 3 pins to achieve the desired motor behavior with only 3 wires.
