05-18-2016, 09:26 AM | #1 |
Dana 44/Warn M7 Help
After performing maintenance on my front brakes, I figured I might as well clean up the manual hubs on my front axle. I would like to remove the hubs and check/clean/re-grease all bearings. The problem I am running into now is that I cannot figure out how to remove the washer (with holes) between the two lock nuts.
Does this washer spin off or should it pull off? I am having trouble finding good rebuild/maintenance info online for these hubs. Also, when I re-assemble, any idea of lock-nut torque requirements? As always , any help is greatly appreciated.
'66 GMC K25 (305 V6, SM420) aka "Mabel" Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082 All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado |
05-18-2016, 09:33 AM | #2 |
Re: Dana 44/Warn M7 Help
It just pulls off.I use a bent ice pick to get them out. The fun one is the big snap ring. I use the ice pick to help with that one also.
05-18-2016, 10:17 AM | #3 |
user # 2756
Yep, just pull it off. It has a tab that slides in a grove on the spindle. I use a dental pick that has bee re-purposed for automotive work.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
05-18-2016, 11:40 AM | #4 | |
Thanks everyone for the info!
05-18-2016, 12:52 PM | #5 | |
user # 2756
Jim
05-18-2016, 05:21 PM | #6 | |
Also, check the inner bearing race to make sure it is in solid and not spinning, real common on those hubs |
05-18-2016, 07:32 PM | #7 |
20' Daredevil (Ret)
This may be off base, but that looks similar to something in my (K20) front hubs. Not sure what it's called.... a collar? It is threaded on, and held in place by one (or maybe two) tiny allen-head screws inside one or two of those holes. Back the screws out and you can then unthread the collar. under that you'll find a slotted washer. The allan screws extend into the slots, and keep the collar from spinning off.
05-18-2016, 08:39 PM | #8 |
Does that tab ring with the holes go on a pin sticking out of the inside big nut on that year axle kinda like my '81?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
05-19-2016, 12:24 AM | #9 |
05-19-2016, 07:57 AM | #10 |
They can rotate a bit and jam in that key way, but grease creates a suction as well. I like to use two picks to make it easier
05-19-2016, 09:20 AM | #11 |
So an update...
I brought a few heavy-duty scribes/picks (with 90 deg. ends) home last night and after spending almost 2 hours on it, I still have not gotten it off all the way. While I made progress, there is still at least 3/8 worth of threads before I am off. It is pivoting on the threads and acting as though there is interference between in I.D. of the washer and the O.D. of the threads. My guess is that the washer I.D. was damaged or tolerances were off during the manufacturing process. I am going with the latter as there seems to be no damage. I am going to do some digging today and hopefully I can purchase a new one. If I can, I am going to cut this one off.
05-19-2016, 09:22 AM | #12 | |
05-19-2016, 11:21 AM | #13 |
It's just a washer. Being an old drum brake system the nuts may have been changed or upgraded years ago and the thickness of the 'tab' may be just that....too thick (wide). Nothing a sharp flat file can't take down before it goes back together
05-21-2016, 11:12 AM | #14 |
It's off. 5 minutes with a dremmel carbide bit. Figured I needed to replace it anyway. Bought new washers for both sides and will replace inside spindle seals as well so I can remove and repack all bearings.
05-21-2016, 12:07 PM | #15 | |
I have one that broke and replaced with a full floating old rear axle tap washer
05-21-2016, 01:10 PM | #16 |
05-21-2016, 03:49 PM | #17 |
I bought mine from 4wheelerparts.com was $3 and change for two.
05-22-2016, 12:21 AM | #18 |
http://www.4wheelparts.com/Drivetrai...&t_pn=WAR32720
http://www.4wheelparts.com/Drivetrai...pn=D%2fS28068X This Stage 8 Locking Spindle Nut doesnt look to swift. Only one nut and only the tab and slot in the spindle to keep it from loosening. Need a 2nd jam nut. Stock set up looks more reliable http://www.stage8.com/xlock.html
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting Last edited by GSP7; 05-22-2016 at 12:44 AM. |
05-22-2016, 01:08 AM | #19 |
What technique do you other guys use tightening the outside jam nut with the special socket.
I just tighten the jam nut with a short breaker bar. Anyone use a drop of removable locktight? I never have
05-22-2016, 12:40 PM | #20 |
After you set the wheel bearing preload with the inside nut, you slide the washer on, and then tighten the outer nut on the washer. No locktite - just tighten the heck out of it. I don't have a spec for "heck-to-ft/lbs" but I usually get silly tight on the outer one. I will try to check my Chiltons and see what it says the Dana 44 outer nut should be torqued to.
05-22-2016, 01:30 PM | #21 | |
05-22-2016, 11:55 PM | #22 |
The inside nut torque I don't know. I have done this job on front and rear wheel bearings so many times I cannot count. On the inside, I pack the bearing with grease. Then tighten while spinning the hub and get it pretty tight. This is just to seat the bearing. Then I back off, and tighten again but not as much...sort of get some firm drag, then back off a little. I have never done 50 ft/lbs and then 1/4 turn back off. That seems rather loose. Once you are satisfied with the preload (however you choose to do it), then the outer nut can get tightened down real tight. The outer nut is going to keep your inner nut from backing out and taking the wheel off with it! Good luck
05-23-2016, 12:47 AM | #23 | |
The 1/4 turn back off seems like 3/16 to much to me. I tighten them down and put the wheel on and to see if there is any play I push and pull on the top and bottom of the tire. If it is to loose you will feel it. I then spin the tire and tighten the first nut until the tire just stops spining really free. Then I just back it off bearly and put the other nut on and tighten the crap out of it. Run it for a mile or so if the hub is hot it is to tight.Then jack it up and push and pull the tire on the top and bottom if it moves it is to loose. If all is good run it some more and check it again in 20 or so miles if it is good you should be good to go for a long time. |
05-24-2016, 05:17 PM | #24 |
That's how I do it too
I always do it with the wheel and tire on so you feel any looseness
