Old 04-17-2017, 12:11 AM   #1
siggyfreud
siggyfreud's Avatar
Brake line routing - will it clear?
Hey all,
Just took a shot at starting to run my front brake lines. Been so long since I've had an engine in here I'm not sure whether or not these will be okay RE exhaust manifold/headers for a SBC V8.
Thoughts?
siggyfreud is offline   Reply With Quote
Old 04-17-2017, 06:24 AM   #2
PGSigns
PGSigns's Avatar
Re: Brake line routing - will it clear?
They may be good but with so many header choices you may have to make an adjustment. I looks like you have plenty of tubing to be able to do that. I would slide the inner fender on and see how it looks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-17-2017, 09:37 PM   #3
'63GENIII
'63GENIII's Avatar
Not sure if this pic will help. This is how I routed mine when I had the fenders off. I put my "flex loops" down inside of the frame rails. Only clearance issue I had was where the speedometer cable comes through the firewall. It ended up going in between the front and rear brake lines on the way down the firewall.
Its not the best pic or bends but they both follow the clutch line and are way out of the way of the headers and anything else. If you look at the lower fender support you can just see them sneaking by.
Not my idea. There was a member here that had a Burb with the cleanest engine compartment I've ever seen. He was the inspiration for my routing. Wish I could remember who it was.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-17-2017, 11:08 PM   #4
siggyfreud
siggyfreud's Avatar
Thanks for the info and help guys! Got them routed and for now will just see how the engine fits once I get it, as if I have to do it again I'd rather wait and not speculate further. Chris that setup looks really nice!
Old 04-17-2017, 11:11 PM   #5
'63GENIII
'63GENIII's Avatar
Thanks Siggy. Just out of curiosity, what type of tubing are you running? Steel or copper / nickel?
Chris
'63 k15 long step
Old 04-17-2017, 11:40 PM   #6
siggyfreud
siggyfreud's Avatar
The copper/nickel. It's easier to bend and supposedly much more corrosion resistant, since the metal itself resists corrosion, vs the coating they put in steel.
I'll likely redo mine eventually even just to make it look nicer, but for now it's function over form. Bending these to look nice is turning out to be as much art as it is science.
Old 04-17-2017, 11:49 PM   #7
'63GENIII
'63GENIII's Avatar
Used the same stuff here. You're right though. It is as much art as science. I bend pipe for a living and the brake lines made me crazy. I went through 2- 30' rolls of the stuff just to do 25' of pipe. After the 2nd time around, all I was worried about was leaks. I stopped trying to make it perfect and started not looking at it anymore. LOL
Chris
'63 k15 long step
