Old 12-02-2018, 02:00 AM   #1
18Z
Active Member
18Z's Avatar
NP435 Repair Manual
Does anyone have a PDF copy of the GM Truck Unit Repair Manual X-7B-08B, Transmission New Process 4 Speed Model 435. I am about to rebuild one. I have the 18 page ford one and the 10 page chevy one out of the chassis manual but the one above is a 26 page one that I can't find.
Kirk
18Z is offline   Reply With Quote
Old 12-03-2018, 11:58 AM   #2
Willys_MB
Willys_MB's Avatar
Re: NP435 Repair Manual
I also have this transmission. There really isn't a lot of information out there. Everybody says there is, but actually finding information is challenging. Have you looked over this website?
http://www.novak-adapt.com/knowledge...s/manual/np435
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 12-03-2018, 11:51 PM   #3
18Z
Active Member
18Z's Avatar
I have checked that website, I found the manual I was looking for on a Ford forum tonight, but thanks for the info.
Old 12-04-2018, 11:40 AM   #4
Willys_MB
Willys_MB's Avatar
Care to share the manual on here?
Old 12-04-2018, 08:33 PM   #5
El Dorado Jim
I have never heard of the New Process 435 4 spd trans...what year is it? I have heard of the SM420 and the SM 465, I have the SM465 in my 72
El Dorado Jim is offline   Reply With Quote
Old 12-04-2018, 09:09 PM   #6
WorkinLonghorn
WorkinLonghorn's Avatar
Here you go Jim; I have one in my truck. Had a SM465 in my last '69 and like this 435 a LOT better. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed (same as Chevy "Longhorn"), 350 ci. mild RV cam, NP 435 CR 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 12-05-2018, 01:14 PM   #7
Willys_MB
Willys_MB's Avatar
The NP435 was a Chrysler product. My understanding was that it came standard in GMC, but was an option in Chevy trucks, but that could be wrong. It's a standard 4 on the floor with a granny gear. I just had mine apart and I was surprised at the shape it was in. The tranny was dated 1967 and in my 1968 truck. I'm pretty happy with it, so it's staying!
Old 12-05-2018, 05:28 PM   #8
El Dorado Jim
thanks, I didnt know they put these in Chevys, I have seen them in Fords, didnt know who they were made by
Old 12-06-2018, 01:58 AM   #9
Bob B.
The NP435GA transmission was the 4 speed manual used with the GMC 305 and 351 V-6's in 4X2 trucks, and was also offered as an option in other '67-'72 Chevy and GMC trucks. It's a heavy duty unit but unlike the SM420 and SM465 it is a close ratio transmission that does not have a 'granny' low ratio 1st. gear. They even use a different knob, marked 1-2-3-4 unlike the L-1-2-3 knob sometimes used on the Muncie transmissions. Ford, Dodge, and IH used other wide ratio versions of the 435 that did have a 'granny' 1st. gear.
My '67 has a 435GA, and I normally use 1st. gear when driving. 1st. gear is a much higher 4.56:1 than the 7.05:1 low gear of a Muncie. The GMC V-6's made so much torque off idle and at low r.p.m.'s a very low 1st. gear was not necessary.
Some '67-'72 Chevy and GMC sales literature lists the 435GA as a 'close ratio 4 speed'. I think over the years many mistakenly believed this referred to the Muncie M21 'Rock Crusher', which was never offered in any trucks other than the El Camino.
The Ford NP 435 shop manual should be fine, the other differences between the regular 435 and 435GA are minor.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 12-06-2018, 11:37 AM   #10
Willys_MB
Willys_MB's Avatar
That's interesting. Mine definitely has a granny gear. Max speed of ~5 mph. I rarely use it and always start in second gear. I wonder if that's the difference between the NP435 and NP435GA...
Old 12-06-2018, 11:58 AM   #11
HO455
HO455's Avatar
According to the Novac site (above link) the NP435 has several different gear sets with granny and with out.
1st 2nd 3rd 4th (direct) Rev.
NP435A (Dodge, GM) 4.56 2.28 1.31 1.00 5.64
NP435L (Ford, Dodge, GM) 6.68 3.34 1.66 1.0 8.26
NP435D (GM) 4.90 2.29 1.19 1.00 6.06
NP435E (Ford) 6.68 3.34 1.74 1.00 8.26
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 12-06-2018, 12:19 PM   #12
A1971Blazer
A1971Blazer's Avatar
A lot of the 435s that are in Ford trucks have extra ears cast on the front of the housing that can be drilled to fit a GM bellhousing...the 435 is a tough transmission much like the 465 Muncie....
I have a Ford435 with a driver drop NP205 that I'm saving....for a future use....?
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 12-06-2018, 02:34 PM   #13
Bob B.
Yes, I think the suffix letters identify ratios. I should have added that GMC used a lot of NP435's with 'granny' first gears in 4500/5500/6500 medium duty trucks. The 'GA' version is commonly seen in GMC V-6 pickups.
Old 12-07-2018, 12:05 AM   #14
18Z
Active Member
18Z's Avatar
Here is the link to one of the the GM manuals:
http://www.fordification.com/forum/v...c.php?p=451621
Copyright ©2000 - 2019, vBulletin Solutions Inc.
