08-21-2013, 01:10 PM | #1 |
Alternator wiring...not charging
I have a problem with the alternator not charging the battery ,anyone have a diagram or clear pictures of how the alternator is wired?
Posted via Mobile Device |
08-22-2013, 06:29 AM | #2 |
Java Mechanic
Re: Alternator wiring...not charging
There are a number of diagrams in the "stickies" above. If you have trouble finding something people here can help but we'll need to know more details about your tuck to find the correct information.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
08-23-2013, 11:34 AM | #3 |
Msgt USAF Ret
Try these,
http://forum.73-87chevytrucks.com/sm...?topic=11766.0 pick the one that applies and click on it then click on the diagram and the magnifier will enlarge it. The 77 to 80 SBC one seems to show the wiring pretty well but I didn't see one with the key switch in it. Most of these trucks were wired the same in that, The large red wire from the alternator goes to the starter and ties into the large cable through a fusible link. The no. 2 terminal on the alternator has a red wire that also runs to a positive battery connection which is hot anytome the battery is connected. You can be pretty sure that the no.1 wire a brown wire will go through the firewall and run to the ignition switch. If you have a charging light instead of a battery gauge it may go to the dash and tie into one from the ignition switch. This brown wire will have a resistance somewhere in it which turns on the alternator regulator and protects the diode trio inside the alternator. The resistance also prevents engine run on after the key is shut off.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
