Old 07-17-2018, 07:55 AM   #1
chrismoore701
chrismoore701's Avatar
Looking for a brake switch plug 79 C10
I have been having brake light problems for a while now, narrowed it down to the brake light switch plug. I have a 79 c10 frame off with a new painless harness. I believe I used the original plug for the brake light switch. it looks fine. Measured for continuity across the switch and it works. Measured 12 V for the power side of the plug and all good. connected plug, pushed brakes, no power to the other side of the plug. removed wires from the plug and connected straight to the switch. All is good. I have no idea.
Anybody know where I can get this plug?
Advanced, Autozone, local hotrod shop, classic parts of America and LMC, no good.
I can always just connect insulated connectors to the switch, but would like to have it correct.
Thoughts?
thanks
Chris
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 07-17-2018, 08:31 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Looking for a brake switch plug 79 C10
The connector for that switch is a Packard 56 custom Female plug. Shell # 2984235
Go yard surfing with your Packard terminal extractor...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-17-2018, 10:02 AM   #3
Bandit130
Bandit130's Avatar
If you have a bad connector, then check this site out.
http://www.repairconnector.com
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 07-20-2018, 07:48 AM   #4
chrismoore701
Any body else out there? Not like you can see the plug and I can replace with insulated connectors, but would like to keep it original
Chris
Old 07-20-2018, 09:00 AM   #5
CSHADES
CSHADES's Avatar
There should be a repair shop in your area that does electrical repair that would have Packard 56 terminals and the tool to crimp it or buy the tool and terminals and do it yourself. The whole setup doesn't cost much and you can fix any other electrical problem on the truck. just replace the terminals and slide back into the original plastic body.
CSHADES is offline   Reply With Quote
Old 07-20-2018, 05:03 PM   #6
chrismoore701
it is the plastic body I am looking for. For some reason the brakes do not work when I have that plug hooked up. Right now I have the the plugs directly on the switch, I have the parts and the tool for the direct connect. I am just looking for a new housing
Chris
Old 07-20-2018, 06:52 PM   #7
CSHADES
CSHADES's Avatar
sorry-misunderstood. the plastic body shouldn't have any effect on powering the switch if the wires are all the way seated in the body and the body seats on to the switch completely.
Old 07-20-2018, 09:00 PM   #8
Sabaka454
Sabaka454's Avatar
https://www.ebay.com/itm/Brake-Light...sid=m570.l1313
Sabaka454 is offline   Reply With Quote
Old 07-22-2018, 01:18 PM   #9
chrismoore701
Agree. everything works. But when i use the plug it does not. I don’t get it either.
Chris
Old 07-22-2018, 07:28 PM   #10
hatzie
Moderator
hatzie's Avatar
The AC Delco PT142 is the connector shell and pigtail. Just buy one of them and extract the terminals.
Voila. The PT142 becomes a Delphi Packard 2984235...
The Brake lamp switch gets power from the fuse panel on one wire and the output wire runs to the Pak Con harmonica plug on the steering column.
The White brake light switch wire runs through the harmonica plug to the turnsignal switch and power from that wire gets routed to both rear turn wires by the switch. If the turn switch is dodgy it'll keep your brake lights from working.
Do both rear turnsignals work on Hazard and individually when LH & RH turn is selected with the ignition on?
Do you have juice on the Orange brake plug wire? This should have power regardless of ignition switch position.
Old 07-22-2018, 09:23 PM   #11
chrismoore701
I have checked all that. All works. Even replaced the turn signal switch because it was acting funny. Problem came back. Checked the switch it works. Checked the power wire on the plug and have 12 volts. Plug it on the switch and now power to the other side. Pull the terminals out and wire direct and they are still working after a week. I don’t get it
Chris
Old 07-24-2018, 10:47 AM   #12
chrismoore701
I redid the original plug. Adjusted the tabs a little. Working for now. Will keep tabs on it and change it to hard wire if needed
Chris
Chris
