05-09-2023, 02:37 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Silverado 6-lug axle swap.
Will a 2006 Silverado 1500 rear axle fit onto a 1969 3/4 ton?? I'll just convert the front hub to 6-lugs if the swap is easly possible. Thanks.
05-09-2023, 03:02 PM | #2 |
Re: Silverado 6-lug axle swap.
Put an 06 2500HD axle in the back of my 72 K10. It is 1.5"-2" wider than stock, matches the front D60 I installed. Shock mounts and spring pads were removed from new axle and new ones installed as they are no where near close.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
