08-31-2017, 07:42 PM | #1 |
Need help setting the timing of a 305
Hi, guys! I just broke in a mildly built 305. Seeking some advice from the 305 experts, please... and please don't criticize my engine choice lol. I had a reason for going that route - the safety of a teen-ager.. ugh!
9.7:1 compression Rebuilt 305 HO heads Comp Cams XE256 full cam kit Edelbrock Performer RPM intake Edelbrock 1403 carb (500 cfm) Stock HEI distributor Stainless shorty headers I used a stock harmonic balancer with the zero mark painted white but it has no numbers on it. Broke in the cam today - that went fine.. Straight headers right now and it's too loud to get a good feel for the timing. I presume I need some timing tape... What initial timing should I start with and how much total timing should this engine need? Thanks for any input! Posted via Mobile Device Last edited by Econman; 08-31-2017 at 08:31 PM. |
08-31-2017, 08:55 PM | #2 |
Re: Need help setting the timing of a 305
You'll need to experiment but here's some good info on figuring it out.
http://www.badasscars.com/index.cfm/...d=76/prd76.htm |
09-01-2017, 12:39 AM | #3 |
There's no timing tab on the timing chain cover? And btw that 305 seems like it'll be pretty sweet... still be plenty o' motor for a teenager.
09-01-2017, 12:58 AM | #4 |
Is that a 350 cam spec or a 305 cam spec. May be kinda small for the compression
09-01-2017, 11:19 AM | #5 | |
Unfortunately you have open headers, so the ear method won't work so well. EDIT: There is a nice discussion and picture here of what you should be seeing: http://67-72chevytrucks.com/vboard/s...d.php?t=151464 or maybe this one, depending on the style used in your engine: https://www.thirdgen.org/forums/tech...et-timing.html (see post #6)
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 Last edited by mattfranklin; 09-01-2017 at 11:26 AM. Reason: found a helpful link |
09-01-2017, 01:28 PM | #6 |
My 305 had the timing mark at the 12 o'clock on the stock H/Bal Don't know if all were this way.
1961 chevy K10 my build is------------61K10 build |
09-01-2017, 02:45 PM | #7 | |
The engine runs better the more throttle, but it is rough and wants to die pulling out of the hole. It is a stock/rebuilt TH350 with 1,750 stock stall converter. I haven't adjusted on the carb yet. I need to get the exhaust on it and then I can tell more about it. It rattles my teeth at this stage. |
09-01-2017, 02:46 PM | #8 |
Yeah, it has a timing tab. I think more than anything I am using an old-school race engine builder that is near retirement and isn't equipped to dial this timing in with a quality gun and is cranky about trying to getting the advance curved properly.
09-01-2017, 02:47 PM | #9 |
09-01-2017, 02:49 PM | #10 | |
And yes, you're right! These shorty headers open are deafening.. lol |
12-03-2017, 06:31 PM | #11 | |
Picture Of The Wire And Where Its At Would Be Very Helpful Thank You Harley03joe
1931 Ford Like New And For Sale 2004 Harley Davidson Heritage Classic 1987 Chevy R 10 Silverado 2007 Azera 2011 Cadillac CTS Premium |
