03-24-2019, 08:04 PM | #1 |
72 Gas Tank
I need to order a new gas tank for my 72 truck because its been sitting for years. What all do I need to order besides the gas tank? A sending unit? I know 72 gas tanks are a little different than the 67-71, so I want to make sure I order the correct stuff. Thanks.
03-25-2019, 01:41 AM | #2 |
Re: 72 Gas Tank
You didn't state C10 or C20. There is a difference in the tanks.
03-25-2019, 06:22 AM | #3 |
Re: 72 Gas Tank
03-25-2019, 08:01 AM | #4 |
Re: 72 Gas Tank
If you are going to spend the time to chanke the tank,put in a new sending unit also a new neck grommet
05-18-2019, 05:06 PM | #5 |
Re: 72 Gas Tank
Tank. Sending unit. Grommet. All new lines.
The old lines rust on the inside.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
05-18-2019, 09:59 PM | #6 |
Active Member
Re: 72 Gas Tank
sucks I have an original 72 tank sitting here I just took out of my truck.
05-18-2019, 11:08 PM | #7 |
Re: 72 Gas Tank
Ok, so I tried doing my research.
Specter from rockauto is best repop tank. According to this site. Still a debate on EEC or not. Gas smell maybe possible if you dont hook up vacuum can. Get new line set somewhere. Don't matter. They all come with one piece that doesn't match up. It sounds kinda easy. I just hope it gets done right the first time. Fuel system seems to be finicky. It has to be done just right it seems Does anyone have some more suggestions?
05-19-2019, 12:44 AM | #8 |
Active Member
Re: 72 Gas Tank
Im using a blazer tank from a late 80s EFI blazer with pump in tank. going to cut a hole in side of my bed for filler neck/cover
05-19-2019, 02:07 AM | #9 |
Re: 72 Gas Tank
Any thought about relocating the tank to the bed? I went with a Boyd’s welding tank and couldn’t be happier.
