Old 05-01-2017, 01:49 PM   #1
kevinc
kevinc's Avatar
Strange check engine light
1988 C1500, 350 tbi. 2 wheel drive 4 speed automatic.
Seems like when I'm at cruising speed the CEL comes on. It will stay on for quite a white, then shut off on its own. When I come to a stop the CEL goes out. I stopped at Autozone to hook up a scanner and no codes are being stored. Truck runs great otherwise. Any ideas? It's really annoying me. Egr related?
Thanks,
Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 05-01-2017, 08:12 PM   #2
sntrym95
sntrym95's Avatar
Re: Strange check engine light
Sounds like EGR. The scan tool at Autozone probably can't read it. Try the paper clip method by jumping pins A & B on the OBD I connector and wait for the SES light to flash codes
Mike
sntrym95 is offline   Reply With Quote
Old 05-02-2017, 01:48 PM   #3
abig84
abig84's Avatar
i second the egr valve code. i have a 1990 and about 5 years ago i hit the highway and after about 10 minutes the light would come on. i was able to scan mine as i worked basically right off the highway. changed the egr valve and went away. only CEL ive ever had with this truck in the past 7 years
abig84 is offline   Reply With Quote
Old 05-08-2017, 10:05 AM   #4
kevinc
kevinc's Avatar
I borrowed a hand operator vacuum pump to check it out. Sure enough, the EGR wouldn't hold any vacuum. So that's the next thing on my shopping list.
Thanks again,
Kevin C
Old 05-08-2017, 03:16 PM   #5
sntrym95
sntrym95's Avatar
Make sure you get the correct EGR valve, and stay away from universal ones. You may have to order one vs going to the parts store. Pull the part number from the one you have to verify the correct part.
Mike
Old 05-09-2017, 07:54 AM   #6
Kudzupatch
Kudzupatch's Avatar
I will second this. They are not exactly cheap and it is cheaper to buy a GM to start with than buy one to replace the aftermarket unit that doesn't work correctly!
Kudzupatch is offline   Reply With Quote
Old 05-09-2017, 10:11 AM   #7
kevinc
kevinc's Avatar
I ordered an AC Delco valve. Should be here hopefully by the weekend.
Old 05-11-2017, 07:10 PM   #8
prjab95
Just wanted to say that I tripped over this topic the other day & it just so happened that I was getting engine light as well on my 95 sierra when I hit highways! pulled off EGR valve & this is what I found!
prjab95 is offline   Reply With Quote
Old 05-12-2017, 11:15 AM   #9
Jeepwm69
I need to replace the one on our 95. I ordered one that I thought would be the correct part.
I ordered a Delco and got a "universal" part.
http://67-72chevytrucks.com/vboard/s...d.php?t=549711
Sent it back for credit, and since the truck is seldom driven, I never have gotten the correct part.
Think I'll go ahead and order one. Where are ya'll getting the correct EGR's (not the universal type)?
Jeepwm69 is offline   Reply With Quote
Old 05-12-2017, 11:33 AM   #10
sntrym95
sntrym95's Avatar
The one I got is the link I provided in that thread. https://www.amazon.com/ACDelco-214-5...dp/B000C9GLEI/
There were a couple different EGR types, so the one above is a negative backpressure valve. You'll need to compare the part numbers to ensure you get the correct one.
Mike
Old 05-12-2017, 11:36 AM   #11
sntrym95
sntrym95's Avatar
You can also try a local (not chain) auto parts store. They buy from multiple suppliers and may be able to find an OEM part.
Mike
