Old 01-17-2019, 10:01 AM   #1
Dilemmaofny
Porterbuilt
Hello everyone
I have a question. Hopefully someone can help.
I have a 68 c10 I’m running porterbuilt extream version front an rear.
With a two piece driveshaft. I’m having clearance issue with the rear of the cab. Is this normal where I will have to notch the rear of the cab
Dilemmaofny is offline   Reply With Quote
Old 01-17-2019, 10:55 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Porterbuilt
Do you have a slip yoke in the rear drive shaft?
I think most avoid this issue with the design of the driveline and where the carrier bearing is placed.
Keith
Convert to disc brakes.
Old 01-17-2019, 11:04 AM   #3
Dilemmaofny
Re: Porterbuilt
This is how it’s set up
Old 01-17-2019, 11:47 AM   #4
lolife99
lolife99's Avatar
Re: Porterbuilt
Do you have a slip yoke in the rear shaft?
If not,... you will need one.
Otherwise you'll destroy that stock carrier bearing.
Also,... your truck must be a longbed truck to have the trailing arm crossmember at the rear of the cab.
That's probably the issue.
Keith
