Old 12-03-2012, 03:19 PM   #51
HouldenCaulfield
Re: Hub caps on truck question
I just bought a pair of OG 64-66 hubcaps for my truck. It looks like, however, I may have later model wheels. The little "nub" that is on the center part of the wheel that generally holds the cap on, is on the outer edge of the center ring instead of the inside. Did chevy make specific wheel designs for 64-66 to match their caps? Or, will I have to make something work similar to your trick above?
HouldenCaulfield is offline   Reply With Quote
Old 12-03-2012, 03:28 PM   #52
1963c-10
1963c-10's Avatar
There were several different rims. The earlier rims had clips as did some of the 3/4 & 1 tons. There was also a 3 bump rim (drum brake) and a 4 bump rim (disk brake). Look at thread #79 on hubcaps
1964 Short bed trailer
Old 12-03-2012, 03:35 PM   #53
HouldenCaulfield
These are the caps my 64 came with...
Old 12-03-2012, 04:01 PM   #54
1963c-10
1963c-10's Avatar
Those are 73-87 caps.
Old 12-03-2012, 04:03 PM   #55
HouldenCaulfield
so, I can assume the wheels on this truck are from 73-87?
Old 12-03-2012, 05:36 PM   #56
1963c-10
1963c-10's Avatar
Can you post a pic of them?
Old 12-03-2012, 08:28 PM   #57
Auctioneerhere
Most likely.
Auctioneerhere is offline   Reply With Quote
Old 03-03-2013, 02:56 PM   #58
92sierraslx
92sierraslx's Avatar
any updates on what clips wprk best as i just scored a set of 5 73-87 4x4 8" wide i "believe" wheels for thirty five bucks and want to run some sort of poverty cap or hub cap instead of the exposed lug nut center cap any new info is appreciated thanks
92sierraslx is offline   Reply With Quote
Old 03-03-2013, 04:33 PM   #59
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Hub caps on truck question
ShopVintageWheels.com
http://www.shopvintagewheels.com/?gc...Fckx4AodgCYAIw
hotrodhubcaps.com
http://hotrodhubcaps.com/other_hubcaps.html
http://hotrodhubcaps.com/chevy_hubcaps.html
http://hotrodhubcaps.com/beauty_rings.html
kustoms.com
http://kustoms.com.au/osc/index.php?cPath=29
http://www.jalopyjournal.com/forum/s...d.php?t=629421
http://www.jalopyjournal.com/forum/s...7836&showall=1
https://www.google.com/search?hl=en&...pw.r_qf.&cad=b
https://www.google.com/search?q=hubc...=1866&bih=1065
[/COLOR][/SIZE][/FONT][/B]
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-03-2013, 04:41 PM   #60
markeb01
Senior Enthusiast
markeb01's Avatar
That wheel cover is absolutely wicked looking! The last time I saw anything remotely close to that cool was back in 1959 watching the chariot race in Ben Hur!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-03-2013, 04:54 PM   #61
1Bad62Pro/Street
The Romans were the first to have spinners!!!
Customized 4 Horse Power Chariot.....
Very first Nascar Race???? Ha ha ;-)
Old 03-19-2013, 01:31 AM   #62
rod1701
rod1701's Avatar
I have been following this thread for a little while but it seems to have stalled. I finally got the 73-87 6-lug rallys cleaned and painted. Went with body color (don't use touch up paint online (dot) com) and smaller trim rings but still looking for center cap ideas. My rallys came with 6 lug 4X4 caps but of course 2 are open and they are all four pitted.
Keith, thanks for sharing but I noticed that your idea allows the cap to snal on OVER the center band(?) I was looking for something smaller that fits inside the groove. Very much small economy/police style cap. Anybody have anything new?
1979 C-10 LWB
rod1701 is offline   Reply With Quote
Old 03-19-2013, 01:06 PM   #63
LVPhotos
LVPhotos's Avatar
LMC Truck has new caps.
http://www.lmctruck.com/icatalog/csb/full.aspx?Page=102
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-19-2013, 02:07 PM   #64
1963c-10
1963c-10's Avatar
Haha...love it, but Ben-hur didn't have chrome. Looks like some LED's in there too.
Old 03-19-2013, 02:08 PM   #65
rod1701
rod1701's Avatar
Thanks. I saw these but the smoothies/plain Jane caps are available for repop car rally's that have been machined for truck pattern. I have 6-lug truck rallys 73-87. They have replacements for my application but I wanted something a little different.
1979 C-10 LWB
Old 01-17-2019, 12:19 PM   #66
3757chevy
3757chevy's Avatar
Originally Posted by kieth View Post
Ok here we go----simple hub cap mounting system for rallye wheels:
1. Parts needed----grote steel insulated wiring clips part # 84-7018
Attachment 824278
I had these so do not remember how much they cost but I think about .50 each
2. We centered the hubcap on the wheel then traced the outline of the hub cap on the wheel, backed off about 3/16" and installed the clips.
Attachment 824279
Hoping above all that it would work..........................
3. Tried a 1957 chevy hubcap first---------------and it worked
Attachment 824280
Would rather be lucky than good...... Wheel only with cap and trim ring
4. 57 chrome hubcap with tire
Attachment 824281
I think it looks good, just think what it will look like on a truck and the wheel painted to match the truck
5. Wheel tire, trim ring , and a painted hubcap
Attachment 824282
Now we just have to try it driving down the road but I will tell you it feels very solid and after it is installed it is hard to get the hubcap off since it is held in place by 4 clips..........when I removed it the first time it bent one of the clips back, then all you have to do is push it back in place. I think since the load will be centrifical (out ward) that the clips will work just fine, if not we could weld them in place Kieth
I know this is an old thread. I just saw it. I was wondering how well the wiring clips held up? Or if anyone has a better fix!
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 01-17-2019, 01:13 PM   #67
rod1701
rod1701's Avatar
Lots of cool innovative ideas but I ended up using a centercap from mid 90s wheel. Little shorter than 70s. Turned out okay.
1979 C-10 LWB
Old 01-17-2019, 01:32 PM   #68
3757chevy
3757chevy's Avatar
Any pictures?
MIKE
Old 01-17-2019, 09:15 PM   #69
Klas
Junior Member
Klas's Avatar
Just saying, I wanted 8" steel wheels on my ' 64 panel but still use dog dish hubcaps. I got wheel vintiques. Centered the dog dish hubcaps on the wheels and marked the outline of the hub cap on the wheel. Then welded three tabs on the wheel inside the marked line. They've stayed on there for over 10,000 miles.
Klas is offline   Reply With Quote
Old 01-18-2019, 08:33 PM   #70
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
A guy I know did wheels for his 66 that way. Works well
Old 01-19-2019, 01:55 AM   #71
3757chevy
3757chevy's Avatar
Any pictures?
MIKE
Old 01-19-2019, 01:51 PM   #72
Klas
Junior Member
Klas's Avatar
Attached are pix, sorry for the dirt. First pix is dog dish cap on 8" vintiques wheel. Second shows the three weld beads on the rim.
Old 01-19-2019, 06:54 PM   #73
studeclunker
studeclunker's Avatar
I ran into the same issue with my truck. The '66 C20 wheels had small clips on the inside ring of the rim that held the cap in place, or so I've been told. So, I bought the caps that fit my wheels. '67-early seventies caps may not be 'right' for my truck, but I like them.
studeclunker is offline   Reply With Quote
