07-11-2002, 04:20 PM | #1 |
Firefighter
What kind of Automatic Trans fluid
What kind is the best to use in an automatic 350 or 400 Turbo?
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
07-11-2002, 04:21 PM | #2 |
What is it, Dextron III now?
Just sitting here contemplating contemplation. |
07-11-2002, 04:24 PM | #3 |
any well-known brand of Dexron 3......
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
07-11-2002, 04:45 PM | #4 |
its all about the +6 inches
If you are starting with a rebuilt tranny, and converter...clean out your tranny dooler with some brake cleaner and compressed air, then put in Type F. This stuff is actually better then the dextron stuff.
However, if you are just doing an oil chainge on an existing tranny, or reusing an old verter...go with the aformentioned Dextron 3. |
07-11-2002, 05:09 PM | #5 |
Carolina Classic Trucks
If you are doing a transmission flush I recommend Amsoil transmission fluid. It is 100% sythetic ATF and meets or exceeds Dextron II and Dextron III, Ford and Chrysler type fluid recommendations. They also have Supershift Racing transmission fluid too. You can get it from me or go to www.amsoil.com and order for yourself.
07-11-2002, 05:13 PM | #6 |
Longhorn… you brill holes and run a trans dooler… dude when you leave the house do you notice people looking at you funny? LMAO
1970 Model C10 LWB, Small Block 421 CID, AFR 220 Heads, 1050 Dominator, Super Victor Intake, Comp Cams Mech Roller, Comp Cams ProMagnum Roller Rockers, 13.8:1 Compression, 4500 RPM TCI Converter, TH400 TCI Transmission w/reverse manual valve body w/trans brake, 5.13 Rear Gear on a full Spool, 31-16.50-15 Mickey Thompson ET Streets |
