05-05-2018, 10:01 AM | #1 |
Flaring hard line for AN
I want to go from hard 3/8 stainless line to AN, so I was going to use my hydraulic flaring tool with a 37-degree die.
I have the -6 tube nuts and rings... Is it as simple as put the nut and ring on, single-flare it 37 and you're done? Seems too easy! Any tips or tricks are welcome. I've done a lot of double-flare stuff but have never done a hardline AN flare ever!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
05-05-2018, 02:25 PM | #2 |
Re: Flaring hard line for AN
That's the way I've done it. Same as you, I've done lots of double flares but only a couple of AN.
05-05-2018, 02:48 PM | #3 |
I have used an adapter that had a compression fitting on one side and -8 on the other.
05-05-2018, 03:05 PM | #4 |
That's it! Just make sure your ends are nice and square and de-blurred properly. Use some lube on your dies too.
05-05-2018, 03:34 PM | #5 |
is AN 37 degrees? so SAE is 45 degrees or something like that?
05-05-2018, 03:55 PM | #6 |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-05-2018, 10:20 PM | #7 |
37 1/2 degrees? AN is not SAE . big difference. any way good luck
05-05-2018, 11:03 PM | #8 |
All about them K’s
This... an and jic are basically the same just a different quality of fittings between the 2. Sae isn’t the same.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
