03-22-2017, 04:09 PM | #1 |
Installed trans cooler on my R30
Decided the truck needed a trans cooler since I do use it for towing. I had a spare used cooler on the shelf, so in it went. Lines are -6 and fittings and lines are Fragola 2000 series. Cooler is a B&M Super Cooler. System is plumbed to go through external cooler first, then through factory cooler. I ran a couple L shaped aluminum straps horizontally from the center support to the side of the core support then bolted the cooler to those. Hot fluid into the bottom so that it pushes all air out of the cooler. When I pulled into the parking lot at work the inlet was too hot to touch, and I was able to hold the outlet.
Pics for those who are interested.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
07-30-2018, 11:34 AM | #2 |
Re: Installed trans cooler on my R30
Fixing image links -
07-30-2018, 09:00 PM | #3 |
Nice looking install! Thanks for sharing it.
The fan on your condenser, did you add that? -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-01-2018, 12:39 PM | #4 |
Fan on the condenser is factory. It is tied to engine temp, not the A/C. I will eventually rework the wiring (and install a better fan) so that it does come on with the A/C also.
