08-04-2018, 04:43 PM | #1 |
Trans Cooler for TH400 w/2800 Stall
In the middle of installing a 385 cu in Gen 1 Small Block. I have a TCI TH400 with a new FTI 2800 stall converter ready to go with it. I already installed a deep pan but I also want to run a cooler. A friend gave me a new Derale 21" Frame-rail/Heat-sink type cooler. I like the idea because it won't block as much of the radiator as a plate cooler. I already have a Vintage Air condenser on there.
Question is... Can I get away with putting the cooler under the radiator (behind the Bumper) or should I put it in front of the radiator. I was thinking installing it up and down if I do it in front of radiator. I never tow anything but I do go from Sacramento to Tahoe/Reno, which is a good 90 minute climb. |
08-04-2018, 07:31 PM | #2 |
Re: Trans Cooler for TH400 w/2800 Stall
Regardless of towing or not, I would put it where it can get as much air flow as possible. 2800 stall is going to throw some heat
08-07-2018, 11:49 AM | #3 |
By itself, that is not enough cooler for your application. Do you plan to run it in series with your radiator cooler?
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-07-2018, 11:58 AM | #4 |
After looking into this more I realized the "free" heat sink was not what I need. I gave it back...
I ordered this: DER-13614 Fluid Cooler, Plate-Fin Type, Aluminum, 10.125 in. x 11.875 in. x 1.25 in. Does this seem to be enough? I'm swinging in the dark as I have no experience with high stall converters. Thanks for any advice. |
08-07-2018, 01:29 PM | #5 |
This is a good read on the subject. Discusses various types of coolers, the reasons for using them and brings up some good points about flow restrictions within the fittings you choose.
http://garage.grumpysperformance.com...on-cooler.307/ Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-07-2018, 02:00 PM | #6 |
Thanks... this is good info. Especially how engine temp is affected as well. The cooler I ordered runs -6 fittings, but then the fittings into the trans are no larger anyway, so I think I am doing the right thing.
Looks like my next purchase is a good trans temp gauge... |
