Old 06-22-2018, 03:42 PM   #1
jkk
jkk's Avatar
Cab trim band cut and polished
Cut and polishing the cab trim and bed trim
EZ -OFF to remove the anodizing the 220 grit to remove the grain then 600,800,1000,1500 and 2000 grit and polished on my buffer
jkk is offline   Reply With Quote
Old 06-22-2018, 04:15 PM   #2
TKCR
TKCR's Avatar
Re: Cab trim band cut and polished
That turned out great!! Did you do the same to the tailgate band?
Old 06-22-2018, 06:02 PM   #3
Mathew21
Mathew21's Avatar
Wow nice job!
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 06-22-2018, 06:06 PM   #4
jkk
jkk's Avatar
Yes tailgate band same thing
Old 06-22-2018, 06:15 PM   #5
Danmcg
looks great, but how do you keep it from oxidizing?
Danmcg is offline   Reply With Quote
Old 06-22-2018, 06:19 PM   #6
jkk
jkk's Avatar
Elbow grease and white diamond metal polish. I polish all of my aluminum and wheels etc. pretty regularly so not worried about that...............lol
Old 06-22-2018, 09:17 PM   #7
Whamo
Whamo's Avatar
Purdy!
Just a Hillbilly in the Hood
http://67-72chevytrucks.com/vboard/s...d.php?t=622194
Whamo is offline   Reply With Quote
Old 06-22-2018, 11:09 PM   #8
Dads79GMC
Dads79GMC's Avatar
Beautiful! What kind of buffer are you using? Sanding technique? Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 06-22-2018, 11:27 PM   #9
gmachinz
I bet anybody who gets behind you at night will be blinded like hell too lol. Looks good!
gmachinz is offline   Reply With Quote
Old 06-23-2018, 05:58 PM   #10
77BBGMC
77BBGMC's Avatar
Looks great!
77BBGMC is offline   Reply With Quote
Old 06-23-2018, 06:29 PM   #11
jkk
jkk's Avatar
EZ -OFF to remove the anodizing the 220 grit to remove the grain then 600,800,1000,1500 and 2000 grit and polished on my buffer. When sanding sand a different direction when changing grits so you can tell when the previous grit scratches are gone. 220 done dry the rest is done wet. The buffer is a Harbour Freight 6in cheap job using white rouge. Finish it off by hand with White Diamond aluminum polish.
Old 06-24-2018, 09:36 AM   #12
rickit
rickit's Avatar
I just paid a company to polish my tailgate band like yours and they made a mess of it
rickit is offline   Reply With Quote
Old 06-24-2018, 10:11 AM   #13
rickit
rickit's Avatar
I hope its not ruined
Old 06-24-2018, 10:54 AM   #14
jkk
jkk's Avatar
Looks like they sanded it with sander. You can save it I would hand sand it to start with 220 long ways until those marks are gone the other direction with 400 wet so you can see when the 220 marks are gone the 600 800 1000 1500 2000 and buff it once you get it smooth it will buff by hand pretty good if yo don’t have a buffing wheel
Old 06-24-2018, 11:03 AM   #15
rickit
rickit's Avatar
I appreciate the info, I still cant believe they sent this back to me in this shape,there suppose to be professional company that does polishing and for what they charged me to
Old 06-25-2018, 05:07 AM   #16
Danmcg
That's criminal!
Old 07-15-2018, 08:53 AM   #17
rickit
rickit's Avatar
thanks for the help! I still have sum light scratches in it but it looks 100 percent better Im still mad over what that place did and they charged a premium to
Old 07-15-2018, 03:46 PM   #18
TKCR
TKCR's Avatar
That does look way better. You ought to send that company that ripped you off doing shotty work, an e-mail with the work you did. My god, I would have been livid, if I had gotten my parts back looking like that!!
Just out of curiosity, and you don't have to answer, I would understand if you didn't. But what did that place charge for the tailgate band? And what was the name of the place? I would want to make sure no one else sent their parts to them, jeez.
Old 07-15-2018, 04:24 PM   #19
Danmcg
I agree!
That's the worst workmanship I've seen.... maybe ever!
Old 07-15-2018, 04:32 PM   #20
rickit
rickit's Avatar
concours trim in Newark texas charged 324.70
Old 07-16-2018, 05:20 AM   #21
jkk
jkk's Avatar
Looks good nice job
Old 07-16-2018, 12:21 PM   #22
Pontiac1976
Pontiac1976's Avatar
jkk : Nice work on the cab trim.
rickit : Not good to hear ****ty work then charge you from a Polishing company.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-19-2018, 08:12 PM   #23
bigarmzz
bigarmzz's Avatar
I wish there was a really good polisher you could trust to do these tail gate bands....definitely be worth it if it turned out like your all's
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
