09-26-2012, 09:39 PM | #1 |
dana 60 questions
i am installing a 4 inch skyjacker lift on my 1988 ccsb . my question is on the passengerside of the dana 60, there are two bolts that go into the housing instead of u bolts . should i use studs instead of bolts to secure the thicker leaf springs ?
09-26-2012, 10:49 PM | #2 |
Re: dana 60 questions
Sounds like a good Idea
09-27-2012, 12:48 AM | #3 |
I kept the bolts and beat the crap out of my front end by ramping it and slamming it down but that's just my experience, i have seen people convert them to studs because they either had them break or think its going to break
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
09-27-2012, 01:54 AM | #4 |
Grease Monkey
When I swapped to my Dana 60 I used studs.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
09-27-2012, 08:23 AM | #5 |
Studs.
If the bolt is a little too long, and tightens up in the hole before the spring top plate, then the springs can move around. If the bolt is a little too short, then it could strip out the threads in the housing when you torque it down. For maximum thread engagement and strength, use studs.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
09-27-2012, 08:26 AM | #6 |
Ok. So I was in an accident and the studs broke. I cannot find any new ones without buying the whole bolt kit. Any one got any or a source for some good ones. I have bolts in now but have not driven it yet. Sorry to hijack crewcabshorty but this info will help you too.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-27-2012, 08:26 AM | #7 |
Try an industrial supply house. Measure the leanth of the new bolt required an see if you can get grade 8 shoulder bolts. They will be stronger than most studs, and remember if you use a stud type fastener the nut must be of equal strength.
09-27-2012, 08:33 AM | #8 |
Any drive line, drive shaft, spring shop will have them.
09-27-2012, 10:46 AM | #9 |
McMaster Carr has 5/8-11 grade 8 threaded rod 3' long for $13.43. I didn't see the tall gr 8 nuts though. And I didn't look for the washers.
But by the time you order all that and shipping, you my as well order the u bolt and stud kit for a D60.
09-28-2012, 09:44 AM | #10 |
Offroad design will sell you just the studs.
Posted via Mobile Device |
09-28-2012, 10:07 AM | #11 |
Any suspension place should have or either make the u-bolt, and I went to hardware store and got the threaded rod. Cleaned the threads in the axle, threaded the rod all the way, tightened it then cut off where I has some extra thread. Never had an issue.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
09-28-2012, 10:30 AM | #12 | |
Most hardware stores don't carry grade 8 threaded rod that big.
