Old 09-01-2016, 06:47 PM   #1
Birdman72
Blazer tank swap
Anyone used tank out of 87-91 Blazer to put in frame of 72 chevy. Do they have a sump baffle that will work for efi
Birdman72 is offline   Reply With Quote
Old 09-03-2016, 01:59 AM   #2
'63GENIII
'63GENIII's Avatar
Re: Blazer tank swap
Ive got one from an '89 in my '63. It does have the baffle. Im using it with a '97 vortec. Although different, the pump for the later EFI engines are a direct swap for the TBI pump.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-03-2016, 03:06 PM   #3
Birdman72
The tank I am looking at is a spectra, but it looks like it only has a small pan where the fuel pump sits. Do you have any fuel starvation issues?
Old 09-03-2016, 06:54 PM   #4
'63GENIII
'63GENIII's Avatar
TBH, mine is about 3 weeks away from running. Mine had a pan / baffle inside that was say 7-8" square x 3-4" high and kinda looked like a maze if you will. It allowed for the fuel to stay around the pump. Im assuming for cooling and anti cavitation reasons.
Chris
'63 k15 long step
Old 09-03-2016, 11:02 PM   #5
Birdman72
Ok thanks . I ordered mine today hopefully it will be in this week . I Will let you know how it works
Old 09-03-2016, 11:31 PM   #6
andrewmp6
You could do a write up on the swap if you want.
