Old 08-07-2017, 08:58 AM   #1
Thedude5804
Power steering problem
I have a 97 K3500 6.5. 2inch body lift currently sitting on bald and wide 33's. Every now and then when the truck is warm the power steering gives out at slow speeds. If i break-stand a little and bump the RPMs up a bit it comes back onto power steering. Fluid seems good and no visible leaks. Do i just need a new pump? should i go with a bigger pump? are there other ones you would recommend? Thanks in advance boys.
1994 K1500 5.7 Manual Transmission regular cab stepside
Thedude5804 is offline   Reply With Quote
Old 08-07-2017, 01:24 PM   #2
74CustomK20
74CustomK20's Avatar
Re: Power steering problem
Probably just need a pump. More rpm it'll spin more n move more fluid...
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
