Old 04-23-2011, 09:45 PM   #1
chev-obsession
chev-obsession's Avatar
700R4 crossmember, need suggestions
Hey guys, I'm currently setting the engine/tranny into the compartment. I have a short bed, and want to keep the stock e-brake crossmember.
I have searchered the forum and can not come up with anything for my certain scenario. Is there any way that on a short bed, i can run the 700R4 with the stock e-brake crossmember? I don't mind modifying it as long as it stays in the same location.
Does anybody have suggestions, or seen some one else do something similar to this?
Thanks in advance!
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 04-24-2011, 01:13 AM   #2
Captainfab
60-66 Nut
Re: 700R4 crossmember, need suggestions
You may be able to retain the e-brake crossmember, by lowering it below the trans crossmember. Maybe flip it upside down? If it were me, I would just convert your truck over to the '66-'72 e-brake cable assembly.
Old 04-24-2011, 11:39 AM   #3
SuperWho
How would you do that? I'm in the same boat.
SuperWho is offline   Reply With Quote
Old 04-24-2011, 12:09 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
What I did was crude but effective. Took out the e brake crossmember and cut out the part that holds the lever that holds the cables. Then I drilled holes and used the holes already in the 68 automatic crossmember with spacers to bolt the e brake crossmember to it. I hope I still have it all so I can put it back.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-24-2011, 01:00 PM   #5
chev-obsession
Captain, do you have any pics of converting this over? I also considered fliping it yes.
Do you have any pics of how it looks now?
1965 c/10 swb
1969 c/10 lwb
Old 04-24-2011, 01:11 PM   #6
chev-obsession
Ok, i dont want to move the motor mounts forward so this is what i have,
This one is showing that the tranny still needs to come back and tilt down and clear the fire wall
1965 c/10 swb
1969 c/10 lwb
Old 04-24-2011, 01:37 PM   #7
Chevy Fleetside
no I don't have any pictures. I took it apart and have not put it back together yet. You might have to redrill the frame for the crossmember. For some reason My 65 had two sets of holes and the other set worked for me. My 66 didn't have two sets and I will have to drill the frame to accept the crossmember for the 700.
Old 04-24-2011, 04:05 PM   #8
Woogeroo
ah ha, found it at last!
some good tips in here:
700R4 Transmission for your '60-'65 Chevy/GMC Pickup - tips by persh
-W
Woogeroo is offline   Reply With Quote
Old 04-24-2011, 04:34 PM   #9
Slow Build
Slow Build's Avatar
I thought of the same thread. Thanks for finding it. I'm guessing the suburban crossmember is from a 2WD. I don't see any parking brake accommodations though.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-24-2011, 09:08 PM   #10
chev-obsession
thanks guys, im not so much worried about a crossmember any more, im mainly concerned about how im going to retain the stock e brake crossmember with this trans. i should of clarified this earlier.
i know there are guys out there with a 700R4 in a swb. has anybody heard or seen of guys doing what captainfab suggested earlier?
1965 c/10 swb
1969 c/10 lwb
Old 04-24-2011, 10:52 PM   #11
Captainfab
60-66 Nut
I don't happen to have any pics at the moment. I could take some of a '70 frame that I have, but it looks like Woogeroo has pics in the link he posted. The '66-'72's didn't have that crossmember for the e-brake. They just use a series of cables and hooks/rods. Thgis would be the simplest IMO.
Old 04-24-2011, 10:52 PM   #12
neto
neto's Avatar
Woogeroo thank you. That's a great picture, 1000 words and all.
neto is offline   Reply With Quote
Old 04-24-2011, 11:15 PM   #13
Rich 5150 69
Rich 5150 69's Avatar
You`re at a crossroad here, either you`ll have to move engine mounts forward and install new trans member, or you`ll have to trim lip in firewal to clear trans and still install trans member....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-25-2011, 01:15 AM   #14
chev-obsession
does anybody know of links to the newer cable style conversion? i'm not finding any links.
I apperciate the input you guys are giving!!
1965 c/10 swb
1969 c/10 lwb
Old 04-25-2011, 09:43 AM   #15
kieth
kieth's Avatar
I have a 66 swb fleetside gmc here is a link to pictures o the e brake set up, it is pretty simple, I have a 65 chevy also and the old system is much bulkier and harder to route exhaust around. Kieth www.kieth.smugmug.com go to the 66 gmc gallery.
here is a link to the e brake photo: http://kieth.smugmug.com/Trucks/66-G...39504536_X5Lck
kieth is offline   Reply With Quote
Old 04-25-2011, 10:32 AM   #16
Chevy Fleetside
You can acually just bend the the lip back and the tranny will slide back more. No trimming needed just a BFH.. Just the top part of the lip.
Old 04-25-2011, 11:22 PM   #17
chev-obsession
Allright, thanks guys and I will post up some pics of wht ever I come up with
1965 c/10 swb
1969 c/10 lwb
Old 04-26-2011, 01:55 AM   #18
Captainfab
60-66 Nut
Here are the cables listed at Classic parts.
http://www.classicparts.com/Hardware/products/198/2/0
I don't see the hooks or rods listed at either Classic or LMC.
You might check in the '60-'66 classifieds, or in the '67-'72 classifieds here on the forum. There will likely be someone that has the parts you are looking for.
