Old 03-27-2018, 07:32 PM   #1
bhammer
Used Center Link??
Soooo, I have a 72 GMC 4x4 SWB that I am rebuilding. I got the frame worked up and threw some tough country lifted springs on it with a 4" lift. My question is the steering center link. I had to get a donor one from another truck as my original was damaged. Since they do not make these new, is it acceptable to use a used one, replacing the tie rod end on the end that you can? One end is solid and does not come out, the other can be replaced.
Tough to see in this picture, don't have a better one at the moment.
Any advice?
Brian
bhammer is offline   Reply With Quote
Old 03-27-2018, 08:42 PM   #2
kwmech
Re: Used Center Link??
What you propose will do just fine
Old 03-27-2018, 09:24 PM   #3
GSP7
GSP7's Avatar
What do you mean by Center link ? The whole tie rod
Rock auto has them
https://www.rockauto.com/en/catalog/...e+rod+end,7428
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 03-27-2018, 09:40 PM   #4
bhammer
Rock auto has them
It’s the link that connects the two spindles. On one end it has a permanent tie rod that appears in good shape, the other has a threaded tie rod that can be replaced. Just wanted to be sure this was okay to use.
Old 03-28-2018, 12:45 AM   #5
kwmech
It is not a permanent tie rod. That is the tie rod end, it just happens to be 3-1/2' long. You can update to a later model style with the center tube and the shorter ends also if you want.
Old 03-28-2018, 08:21 AM   #6
There is no center link in this design. That is the tie rod. That is how the ends got to be called "tie rod ends". The only reason to ever replace the tie rod itself is if it is bent or the threads get damaged. I had munged up threads in the '72 K/20 Cheyenne Super I had and used the NOS one I had bought for a Blazer with a bent one. I ended up using a used one on that. Kicking my butt for using that and not a used one now.
Old 03-28-2018, 09:54 AM   #7
GSP7
GSP7's Avatar
He is talking about this,,,, I think... and Yes they do make them New
Old 03-29-2018, 10:50 AM   #8
Yes, a tie rod (assembly, including r&l tie rod ends) is the part that links the passenger side knuckle with the driver side knuckle that the steering arm is mounted to, that the draglink moves by way of the pitman arm connected to the sector shaft out of the steering box. As KW Mech said, and I suggest, you can buy the later "tie rod" which has both (tie rod) ends replaceable. That is GM's improvement for better servicing.
Old 04-11-2018, 01:53 PM   #9
bhammer
Any suggestion on what year/model will work as a replacement? I'd rather have the link with the two ends replaceable than try and use this one. Not even sure if this is correct for the vehicle. The steering stabilizer holes don't seem to mount up to my D44 front axle. Here are better pics of what I am talking about.
Old 04-11-2018, 09:57 PM   #10
'72-up
Old 04-11-2018, 10:30 PM   #11
kwmech
With the top taper knuckles you may have to see if the tubing will clear the bottom of the leaf springs when you install the later model tie rod system. But if that works the tapered hole for the steering shock will be on wrong side, you may have to have the hole re-tapered. OR you can use the top taper tie rod ends and have a piece of tube threaded. Then get a steering shock kit that has the small u-bolts to go around the tubing
Old 04-14-2018, 08:17 AM   #12
I always run the horizontal dual steering stabilizers with wide tires anyway. Started out using stacked dual stabilizers when that was all that was available
Old 09-06-2018, 10:09 PM   #13
Moline
Mines bent on my 70. Can I just straighten it out or is that a no-no?
Moline is offline   Reply With Quote
Old 09-07-2018, 12:56 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I wouldn't try to straighten it. It's already been bent, so the metal has been weakened. If you absolutely had to re-use it, weld a section of angle iron to it lengthwise for reinforcement to help prevent further bending.
For all that trouble, though.... just do it right and buy a new one.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-10-2018, 10:04 AM   #15
First c10
First c10's Avatar
What year front axle is it?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
