11-13-2018, 07:47 PM | #1 |
draw on battery
I have a draw on my battery on my 65 c10. When I unhook the alternator it goes away. So I thought something in alternator is bad and took it to repair shop. He said a couple of things were bad and replaced them. Then it did not charge. So I took it back today and he made it a one wire. I still have a slight draw on the battery until I unhook the alternator wire then no draw What am I missing. I have the voltage regulator unhooked as well. The only thing hot at the new fuse block is the brake light fuse with the key off.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
11-14-2018, 08:05 AM | #2 |
Re: draw on battery
http://67-72chevytrucks.com/vboard/s...d.php?t=760365
http://67-72chevytrucks.com/vboard/s...d.php?t=764386
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 11-14-2018 at 11:24 AM. Reason: added info |
