10-29-2019, 03:07 PM | #1 |
Coil bracket
I've searched, but not coming up with anything, so I'm asking for suggestions. I have an intake manifold with no coil mounting bosses. I'm looking for a bracket to hold the coil, vertical preferably. I saw a photo of one that appears to mount to the intake manifold bolt(s), but cannot seem to find one. any help would be appreciated. Thank you in advance. BTW, this would be for the standard type round coil.
10-29-2019, 08:36 PM | #2 |
Re: Coil bracket
Pontiac has coil mounts from 65-67 GTO's for example that bolt to the rear of the passenger side cylinder head. Summit also has a similar bracket
https://www.summitracing.com/parts/s...RoCzX8QAvD_BwE
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
10-30-2019, 06:38 AM | #3 | |
Old member
Re: Coil bracket
10-30-2019, 09:11 AM | #4 |
Re: Coil bracket
Don't have my '57 2dr sedan here, it's headed to paint hopefully next Monday. I have an original GM '57 dual four bbl intake also with out the provision for the coil bracket as you do. I was able to find a metal coil bracket that mounted to an existing bolt hole on the firewall just to the right of the distributor. I also mounted it vertically but should also work horizontally if wanted that way. Found it on eBay for under $10 shipped. Just a thought, may work for you also.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
