Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-08-2018, 08:53 AM   #1
72 tigger
72 tigger's Avatar
Painting a bed with a metal floor
How do most of you guys paint the inside of your beds? Rotisserie? Paint it in pieces? Stand it on end? Tried to search and couldnít find anything. Thanks
72 tigger is offline   Reply With Quote
Old 12-08-2018, 01:34 PM   #2
mongocanfly
Re: Painting a bed with a metal floor
When i primed mine the 1st time it was on sawhorses very aggravating....then I decided I'd just stand it on end or on its side and do it.....then I built a rottiserie.....rotisserie is absolute best way...
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 12-10-2018, 09:28 AM   #3
MP&C
MP&C's Avatar
As Greg said, rotisserie is best option, next best would be a dolly to stand the bed on. This version lets you get to all surfaces except the front, so that part would need to be done separately. Not my picture or work, an online grab...
Robert
MP&C is offline   Reply With Quote
Old 12-10-2018, 07:52 PM   #4
theastronaut
theastronaut's Avatar
Rotisserie works best if you have access to one.
theastronaut is offline   Reply With Quote
Old 12-12-2018, 10:05 PM   #5
oem4me
oem4me's Avatar
I remember doing this same thing a hundred years ago when I was just a kid. I had no rotisserie or even the means to remove the bed from the truck. I simply did all the prep work and then broke the actual squirting of paint into separate stages, with the bed floor being last. It came out perfect, but I should mention that it was just white single stage enamel. Kinda hard to screw that up too badly. Lol.
Old 12-25-2018, 06:10 PM   #6
72 tigger
72 tigger's Avatar
Donít have a rotisserie, been doing it in stages. Sanded the inner bedsides and masked them off, then laid them on sawhorses and sprayed the exterior. Then sprayed the floor and carefully installed the bedsides and front panel. Last step will be to spray the inside and front panel. Hopefully itíll come out nice
Old 12-25-2018, 09:38 PM   #7
mongocanfly
Thatll work!!...
Mongo...aka Greg
Old 12-25-2018, 11:27 PM   #8
kidatheart
Junior Member
looks nice! What do you do about the seam sealer between the inner bedside and floor? Do you just not reseal it?
kidatheart is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
