Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-23-2018, 05:12 PM   #1
dracko
dracko's Avatar
ISO-free primer
After getting some crazy quotes to do the bodywork and paint on my ‘64, I decided to take on the work up to paint and then my buddy is gonna paint it in a booth at his shop.
I am working in my garage...in the Canadian winter... so airflow while spraying is limited. I keep using fresh charcoal cartridges and move the air best I can while still keeping the garage at painting temps and not blowing myself up.
So far I’ve avoided Isocyantes with epoxy and polyester primer but now the truck is blocked to 180 grit and ready for a 2K urethane? I can’t find any that are iso-free ....that I’ve heard any reviews on. Looking for recommendations from painters.
Anybody used a iso-free primer that has decent fill capabilities, easy to sand and compatible with most paint systems? I’d like to fill the 180 scratches.
dracko is online now   Reply With Quote
Old 12-23-2018, 07:23 PM   #2
Foot Stomper
Foot Stomper's Avatar
Re: ISO-free primer
I don't understand your need for ISO free. There's nothing better than a good urethane high build over an epoxy primer and all of them have isocyanates! Even the polyester primer you sprayed had isocyanates I'm pretty sure.
Autobody chemicals are all very harmful and all precautions should be taken regardless of chemical makeup. If you are using a proper fitting N95 mask, then using primers as you already have been should be no problem. Why do you think you need ISO free urethane primer??
I suggest you go to Carlsons Body Shop Supplies and buy a gallon of Five Star DTM and don't argue the price. It's the best urethane primer money can buy and will sand like butter (if you spray it as per TDS) and will not shrink and reveal your 180 scratches in your paint job. Buying a cheaper primer will only make you work harder sanding it, and will have less filling properties.
Pictured below is the Five Star DTM in white. Check out my build thread in my signature for more pictures. (This truck was restored 30 miles outside Regina)
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 12-23-2018, 07:45 PM   #3
dracko
dracko's Avatar
Re: ISO-free primer
Hey Footstomper, thanks for the reply. I know all paints are full of nasty carcinogenic chemicals, but I’m concerned more about ISO’s because they have been known to “potentially” cause sudden and severe asthma attacks as well as other long term damage...and there is no filter cartridge on the market that filters them out. Polyester primers are activated by methyl ethyl ketone peroxide which doesn’t contain ISO’s.
If I had a way to force fresh/warm air into my garage and keep the fumes down it’d be less of a concern. But as it is I’ll likely be spraying and then vacating the garage until it’s fully cured, then turn on the exhaust fan and clear the air. 5 star sounds great and the right price as far as urethane primers go, but I’m wondering if there is an iso-free option people have used with success. The price isn’t a huge concern since I’m saving a few bucks doing the work myself.
Old 12-25-2018, 09:54 PM   #4
kxmotox247
kxmotox247's Avatar
Re: ISO-free primer
Try looking at the House of Kolor KD3000 primer system. You can intermix the colors to create a shade close to your base color. You can mix as a sealer, medium build or high build. It sands great whether dry or wet. Iso free. You can buy from summit or tcpglobal.
https://houseofkolor.com/formulas/foundation/
Baby Blue's Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=652776
Project 68's Build Thread:
http://67-72chevytrucks.com/vboard/s...17#post8442117
kxmotox247 is offline   Reply With Quote
Old 12-26-2018, 09:37 AM   #5
dracko
dracko's Avatar
Re: ISO-free primer
Thanks man that sounds like the bees knees. Iíll check it out.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
