Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-29-2018, 10:51 AM   #1
65truckowner
65truckowner's Avatar
epoxy primer
My 65 is in epoxy primer now and has been for a couple months. If I decide to paint it do I have to respray the epoxy or can I just scuff the epoxy and then spray the mp 282 over it
65truckowner is offline   Reply With Quote
Old 12-29-2018, 02:27 PM   #2
mongocanfly
Re: epoxy primer
Scuff and spray...
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 12-29-2018, 07:09 PM   #3
MP&C
MP&C's Avatar
Re: epoxy primer
Depends on the brand, some you can scuff and shoot, some needs a tie coat of epoxy again and then your high build (or other) after flashing but before fully cured. Your paint mfr should have a spec sheet that gives application instruction, or if you tell us what you’re using, perhaps someone has experience with it and can fill you in.
Robert
MP&C is online now   Reply With Quote
Old 12-29-2018, 07:53 PM   #4
65truckowner
Re: epoxy primer
The high build primer is mp282 and the epoxy is the same brand. The sheet says must scuff and reapply after so many hours. I usually just spray the epoxy and let it flash then spray the high build but I wanted the back color so I just sprayed the epoxy.
Old 12-30-2018, 09:10 PM   #5
hugger6933
Re: epoxy primer
Spray one coat of mp175 after a scuff with somewhere around 220 grit[ I assume it is black you used] then move on to the high build. I love me some mp 282 I have sprayed hundreds of gallons of it it is some good stuff.
hugger6933 is offline   Reply With Quote
Old 12-30-2018, 10:38 PM   #6
65truckowner
Re: epoxy primer
I was waiting for you hugger to chime in Thanks for the information. I only use mp 282 it works great
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
