Old 01-25-2019, 10:57 AM   #1
lukeembry
85 C10 LT/6L80 Frame off build
I decided to swap my truck from LS/4L85 to an LT/6L80 back in October of 2018, it didn't take long for it to spiral out of control. I thought I would share my build as I work on it. Hoping to have it complete by July 2019
lukeembry is offline   Reply With Quote
Old 01-25-2019, 07:36 PM   #2
SCOTI
SCOTI's Avatar
Re: 85 C10 LT/6L80 Frame off build
Interesting. Most guys would be just fine w/the LS/4L85 combo especially one that looked as nice as what was under your hood.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 01-25-2019, 08:49 PM   #3
Chris74
That truck is so clean
Chris74 is offline   Reply With Quote
Old 01-25-2019, 09:43 PM   #4
lukeembry
Iím just bored with the LS. Want a 6 speed and wanted to update the truck. Engine and trans went to good use in a friends C10
QUOTE=SCOTI;8450988]Interesting. Most guys would be just fine w/the LS/4L85 combo especially one that looked as nice as what was under your hood.[/QUOTE]
Old 01-27-2019, 10:18 PM   #5
lukeembry
Sheetmetal work happening now, due to some repairs 15 years ago I'm going to change out the doors and doghouse for some nice original paint doors, fenders, and hood. box of hardware going out for zinc plating. hoping to be doing body work in the next week
Old 01-30-2019, 04:24 PM   #6
BabyBlue
The Peacemaker
BabyBlue's Avatar
Glad to see someone else doing an LT build. But I am curious as to why you chose the 6spd auto over the 8spd or a manual for that matter. Keeping it a column shift or doing a floor shift?
1978 Chevy 2wd Stepside
aka "Audrey"
79k original miles & now under the knife for
"Project TIMELESS"
2018 CCSB Silverado
5/7 Drop
6.2L
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 01-30-2019, 04:30 PM   #7
lukeembry
Why not a 6L80? it will be much better than the 4L85E that I had. Also I'm not sold on the 8L yet, most I have driven make a lot of noise clunking around. A T56 magnum would have been nice but the cost really adds up to do that. I will keep it column shift with the OE shifter rod assembly
Old 01-30-2019, 06:46 PM   #8
Mattchu60
I really dig that truck - super clean. I like the stance and wheel tire combo as well.
Mattchu60 is offline   Reply With Quote
Old 02-01-2019, 08:08 PM   #9
GMC Guy
GMC Guy's Avatar
Love the setup(s) and the truck is clean as hell. excellent work. I found a 6.2 and 2wd 6l80e, with harness, accessories, and driveshaft, out of a 2012 silverado with 116k miles for 5 grand. Been thinking all day about changing out my cammed L33 and 4l65.
I read some people saying the 6l80 isn't as strong as a 4l80 and can't hold much more than 400hp. Any concerns with yours? or are you staying relatively mild with the LT?
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 02-01-2019, 10:36 PM   #10
lukeembry
a 6l80 will handle much more than 400hp 6l80 is super sensitive to the tune so once someone goes to tuning on them they go to crap. there are lots of people making north of 500rwhp with them. no issues for me, mine will be 420 or so hp so it will last forever
Old 03-07-2019, 11:06 AM   #11
lukeembry
anyone have a 81-87 damage free OE hood near bowling green KY?
Old 04-11-2019, 07:41 AM   #12
lukeembry
new Sheetmetal fitted and ready for some small repair work, sending all the hardware off for clear zinc coating
Old 04-12-2019, 08:13 AM   #13
lukeembry
Rear-end build time, for years I've been using Richmond gears with no issues. I like how they have the pinion depth on the pinion head, makes set up much easier. I will also be using their Richmond Excel axles and set-up kit to freshen up the 30 year old 12-bolt.
Richmond 3.42 gears 49-0070-1
Richmond set up kit 83-1018-1
Richmond Excel axles 92-25192
Old 04-12-2019, 09:36 AM   #14
SCOTI
SCOTI's Avatar
Nice parts.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-12-2019, 09:53 AM   #15
Mattchu60
I am curious- what is the reason for all the body rebuilding - in the pictures the truck looks really sharp already. The Paint appears to be nice as well!
Old 04-12-2019, 10:49 AM   #16
lukeembry
Thanks for asking Matt, I built the truck and did the body/paint work back in 2002. The truck still looked really good but there were several issues I wanted to fix and it just made sense to start over with some nice OE paint sheetmetal and pass the old panels on to someone else that could use them.
Old 04-12-2019, 10:49 AM   #17
lukeembry
Originally Posted by SCOTI View Post
Nice parts.
Thanks keep in touch more to come!
Old 04-15-2019, 09:31 AM   #18
lukeembry
Primer #2 is complete, using all Tamco products on this build. if you are a body man and haven't used Tamco primer you are missing out!
Old 04-15-2019, 11:02 PM   #19
tremman78
tremman78's Avatar
what primer from tamco did you use? im gonna spray some 5311 this week, first time using their products
tremman78 is offline   Reply With Quote
Old 04-16-2019, 07:39 AM   #20
lukeembry
5310, best primer I have used so far. I have sprayed PPG, Dupont, Spies, for years and like this better
Copyright ©2000 - 2019, vBulletin Solutions Inc.
