Old 03-02-2010, 05:03 PM   #1
Jeepwm69
Dash Speakers
What can ya'll using for dash speakers? I saw a post somewhere where a 4 inch will fit in the corners where a 3 1/2 in is from the factory but can't seem to locate it now. Are any of you running a 4x10 in the center or did you fab it up to put something else in there? Not looking for awesome sound, but the 28 year old factory speakers are sounding a little fried so figured I'd replace them when I take the dash pad off to install a cover.
Jeepwm69 is offline   Reply With Quote
Old 03-02-2010, 05:59 PM   #2
ECU PIRATE
ECU PIRATE's Avatar
Re: Dash Speakers
4" will fit but you may have to trash the factory speaker brackets and cut up your dash. Most of the aftermarket 3.5" speakers will have a tweeter that protruds about 1/2 to 3/4" above the speaker. This may make your dash bulge, I have (2) sets that I am trying to figure out for this use: Infinity REF3012 and Polk DB351's. I have been working on a mount to under mount these in the factory 4x10 opening in the center. This should work with all of the dashes from 73-87. I got the idea from a post on here last year. One thing to note is the actual width of this opening ( 9.75" long by 3.75" deep). I am figuring on making a 3/4" plate out of plywood that may be roughly 12" wide x 4.5" deep. Hope this helps but, PM me if you have questions. I can shoot you some pics of what I am talking about
Mike
The Fleet........
68' Camaro - 1st car (restored & still have it)
05' Kia Sportage (Wife's Daily Driver)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my 73'
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle "
ECU PIRATE is offline   Reply With Quote
Old 03-02-2010, 07:45 PM   #3
thrtsxchambers
thrtsxchambers's Avatar
Re: Dash Speakers
Here is my setup, I have 4" mb quartz all the way across. When I ordered the speakers they came with an mount for 2-4" to fit in the middle. The 4" does fit in the side holes but does not fit flush like stock but you still have room under the dash pad where they do not hit. you could make them fit flush but will have to cut the dash, I opted not to. This is not the best picture but you can see where mine are, I cut holes and installed the covers b/c the factory dash is covered with leather. I don't have a pic of the speakers with the cover off but it will be coming off in a few days and can get one then if you would like.
thrtsxchambers is offline   Reply With Quote
Old 03-02-2010, 10:58 PM   #4
Dapper Dan
Dapper Dan's Avatar
Re: Dash Speakers
This is what i did. they fit fine, however like ecu pirate said my dash does slightly bulge on the passenger side. That may be partly because it is a reproduction
http://67-72chevytrucks.com/vboard/s...d.php?t=344303
Dapper Dan is offline   Reply With Quote
Old 03-02-2010, 11:03 PM   #5
USSkoval
Re: Dash Speakers
For my '88 I just used 3.5's in the factory brackets. It's OK, but I would like to ditch them in favor of something larger in the kick panels. For my '77, I mounted dual 4's in the center opening. The frames were large enough that I could bolt the two together and then mount them to the dash. I like that setup.
USSkoval is offline   Reply With Quote
Old 03-02-2010, 11:43 PM   #6
Jeepwm69
Re: Dash Speakers
I'm going to get a dash overlay, and the factory speaker grill areas in the dash pad are absolutely trashed (cracked, split, disintegrating). I'll probably put 4" in there and wallow out the dash pad to get it to sit down like it should. Anyone see a problem doing that?
Old 03-03-2010, 12:43 AM   #7
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
Re: Dash Speakers
i did 4" kickers all the way across i had to make a bracket out of some abs for the middle but the sides fit fine. I did have the glass out when i did it though. i think it will be really difficult to do it with a windshield in the way
staggerd86c-10 is offline   Reply With Quote
Old 03-03-2010, 01:26 AM   #8
54Caddy
GM Addicted
54Caddy's Avatar
Re: Dash Speakers
i have a kenwood 4x10 under my dash thing sounds good man. If you want to go with a stock look. Its a 3 way 400 watt i believe if i remember right.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 03-03-2010, 01:59 AM   #9
thrtsxchambers
Re: Dash Speakers
It is!
Old 03-03-2010, 11:46 AM   #10
jklonowski
jklonowski's Avatar
Re: Dash Speakers
what i did to mine is flip the bracket upside and instead of puting them on top of the dash like factory i put them under the dash. it's hard to explain but if you can picture it in your head its not hard to do. it only took about 45 min to do. what it will do it will give you about 1/2 to 3/4 inches more clearance.
also i used the factory 3 1/2" speaker.
jklonowski is offline   Reply With Quote
Old 03-03-2010, 03:51 PM   #11
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Dash Speakers
If anyone has any pics of 4" vs 3.5" front corner speakers installed that would be great. Im just about to buy front ones cause mine are toast. I would like to go 4" but not if I Have to mod alot or it makes the dash sit higher?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-03-2010, 05:08 PM   #12
Jeepwm69
Re: Dash Speakers
yeah, I'm in the same boat. I would prefer to put a 4" in there, but I want it to look ok without having to do a bunch of modding on the dash.
Old 03-04-2010, 10:28 PM   #13
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Dash Speakers
I went to the local Pick-n-Pull after work today and scores a locking dipstick, heater control, sportbumper licence plate lamp, and 2 front speakers with brackets($22 Bucks). It was nice the dash was ripped off. Im going to see how the 3.5" compare to the 4" speakers for mounting. Under the bracket I noticed there is lots of room so opening the holes should not be an issue...
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 03-05-2010, 12:24 PM   #14
Jeepwm69
Re: Dash Speakers
Pics would be nice......please?
Old 03-05-2010, 02:46 PM   #15
ECU PIRATE
ECU PIRATE's Avatar
Re: Dash Speakers
Try DapperDan. He mounted 4" speakers in the factory location. It looked pretty clean. I would love to see some pics with those factory mounts flipped upside down and installed under the dash. This may solve my whole problem so I can use my Polk db351's that are just waiting..........................
The Fleet........
Old 06-20-2014, 07:32 PM   #16
SkinnyG
SkinnyG's Avatar
Re: Dash Speakers
A bump only because I've just gone down this road, and wanted to show what I came up with for others who are searching for the same thing:
Ditched the original 4x10 single speaker for a pair of old JBL 5-1/4" two-ways I shelved from a car I cut up eight years ago. Adapter made from a dollar store cutting board.
Nostrildamus - 1961 Apache, soon to go under the knife
The Crusty Chevy - 1977 Silverado, shortboxed & dropped, potato-potato.
The Fiendish Firefly - The ultimate engine swap: 5.7lbs in a 1lb bag
SkinnyG is online now   Reply With Quote
Old 06-20-2014, 07:41 PM   #17
tucsonjwt
Re: Dash Speakers
I think you can also add spacers (nuts?) to the mounting areas to bring the speakers down a little and clear the dash pad.
I have 3.5" speakers in the kick panels - but just in a circular hole cut in the metal kick panel. The magnets are a close fit but they work fine. I made triangular wood speaker boxes for the rear speakers in the cab corners. Overall, my setup is OK, but I think if you can do the two speakers in the center that would be a nice stock touch. Being able to control the fade from front to rear speakers is nice, as well as left to right balance, especially on a long drive.
tucsonjwt is offline   Reply With Quote
Old 06-20-2014, 08:40 PM   #18
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Dash Speakers
i used 2 newer stock 4X6,seems great compared to 1 speaker mono lol
i kept the 4X10s for "ashtray replacement" in the Jimmy
John http://www.youtube.com/user/TheMotornut
1978 Suburban4X2-hit while parked RIPzez
1978 GMCJimmy4X4-350/203http://67-72chevytrucks.com/vboard/s...=421767&page=4
1979 GMCJimmy4X2-305/350http://67-72chevytrucks.com/vboard/s...=1#post5200107
1987 Suburban4X4-writeoff hit while parked RIPzez
1988 Suburban4X4-writeoff hit while parked RIPzez
1989 Suburban4X2 - square igloo/SOLD
2002 Fleetwood
2005 Malibu hit by City bus,2nd time a write-off(01/15/16)
2010 Dodge Van-writeoff hit while parked(01/14/15)
Now I just buy shorter trucks!
Love em low,but get me higher
Old 06-20-2014, 08:43 PM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Dash Speakers
used my 88 burb covers and they appear stock
2002 Fleetwood
Old 06-20-2014, 10:58 PM   #20
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Dash Speakers
I did 4" in the outers and 3.5's in the inner. As stated, the 4" speakers i got were a pain to fit. I had to ditch the bracket on the driver side and cut the dash to get the speaker to drop in. The centers clear the dash pad just fine how they are in the picture. THe passenger side 4" hits the A/C duct but its manageable.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-22-2014, 03:23 PM   #21
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: Dash Speakers
I bought this one from LMC, and sounds great, also bought some 4x10 3 ways for behind the seat from ebay for $30 with shipping.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=129
http://www.ebay.com/itm/2-NEW-BOSS-C...item51b60f0d5a
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 03-08-2019, 02:09 AM   #22
ShortHaul
ShortHaul's Avatar
Re: Dash Speakers
brilliant. I'll be 100% adopting this glorious idea. thank you.
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala Sport Coupe
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 04-12-2019, 11:40 AM   #23
Nodnarb76
Nodnarb76's Avatar
Re: Dash Speakers
How is everyone wiring 6 speakers (4 in the dash and two in the rear) with a standard 4 speaker wiring setup?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 04-12-2019, 02:58 PM   #24
rideair
Re: Dash Speakers
In my Suburban, the factory head was replaced with a unit that had four standard speaker outputs (which I ran two to the 3 1/2 in the dash, then two to feed two powered subwoofers under the bench seat). The new head also had four RCA out puts that was used on a 4 channel amp that was used to power 6.5 in the kick-panels and the 4x10's in the rear.
rideair is offline   Reply With Quote
Old 04-15-2019, 01:51 PM   #25
Jeepwm69
Re: Dash Speakers
Initially I tried tying the 4 dash speakers together in the front, and ran the rear channels to the 6x9's behind the seat. Head unit didn't have the power to run them that way, got all kinds of distortion on the fronts, so I unhooked the 3.5's in the middle.
I figure eventually I'll add an amp, run them something like rideair said he's done.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
