Old 03-05-2019, 12:40 AM   #1
james69z28
ideas on wire routing
I am building a 1971 show truck and it was partially started when I bought it. My question is the previous owner smoothed the firewall and other than the power brake booster and emergency brake cable there are no visible holes, they installed vintage air in it and put the bulkhead fittings in the side of the cowl to be hidden under the fender.
I am constantly trying to figure out where to run the wiring and speedometer cable out of the cab and I have a couple of places in mind to drill holes in the floorboard and use rubber grommets to get the underhood wiring into the engine bay and also out to the rear lights ect.. I was just wondering if any of you had experience with this and if you had a good location and/or likes/dislikes on where you did it?
james69z28 is offline   Reply With Quote
Old 03-05-2019, 01:19 AM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: ideas on wire routing
Don't know if this helps, but here's a 71 A/C cab.
If you need a closer shot just ask. The cab is bare.
Tony
71 C10 Custom Deluxe, SWB, fleet, 402/400TH, A/C...Resource intensive
72 Cheyenne Super, LWB, fleet, C20, 402/400TH, A/C. Driver and tinker truck
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 03-05-2019, 02:32 AM   #3
james69z28
thanks, good info.
i'm just wondering where the best place is to cut hidden holes for wires and speedo cable under the truck so you don't see wires when hood is raised.
Old 03-05-2019, 01:31 PM   #4
renegade6
Right above the trans tunnel isn't a bad place to hide holes.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 03-05-2019, 04:12 PM   #5
70sangersean
I would like to see some pics, if you can, of how your vintage air lines were ran through the firewall. I plan on trying to route mine out of site as well, along with some of the other clutter. Thanks
70sangersean is offline   Reply With Quote
Old 03-06-2019, 01:24 AM   #6
james69z28
I can take pics and text them or e-mail them to you, if you tell me how.
I would like to post them here for everyone but I haven't had much luck on forums like this in the past posting pics and it has been a few years since I used photobucket.
Old 03-06-2019, 11:03 AM   #7
Sloonz
I'm constantly blown away at the amount of great info on this site!
Sloonz is offline   Reply With Quote
Old 03-06-2019, 11:27 AM   #8
suville
suville's Avatar
I'd be interested in the heater,A/C lines
suville is offline   Reply With Quote
Old 03-09-2019, 11:23 PM   #9
james69z28
Sent pics in a text, see p.m.
Old 03-15-2019, 01:04 AM   #10
james69z28
will try again--1st try failed to post pic
Old 03-15-2019, 01:15 AM   #11
james69z28
lets see if pics post now?
Old 03-15-2019, 01:25 AM   #12
james69z28
one more inside of cab lines. I don't like them being there but the firewall looks better?
Copyright ©2000 - 2019, vBulletin Solutions Inc.
