10-14-2017, 06:46 PM | #1 |
Speedo gear shaft shroud
Trying to replace the Speedo gear there is a shroud on the shaft I can't figure out how to get off. Tried to google it, but not sure what its actually called Last one I did nod not have this. It's an 1980 C20 but this is not origional trans.
photos here http://s155.photobucket.com/user/pkh...tml?sort=3&o=0 Last edited by tate65; 10-14-2017 at 06:56 PM. |
10-17-2017, 07:44 PM | #2 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Speedo gear shaft shroud
Not sure what tranny you have but is this what your talking about? http://www.73-87.com/7387garage/drivetrain/yokeleak.htm There is an O-ring inside of it. Slide the sleeve foreword if you can to see the O-ring and remove it first, then slide It off the tail shaft. "Output shaft to slip yoke O-ring sleeve" https://www.transpartsonline.com/TRA...sPartsType=350
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 10-17-2017 at 08:25 PM. |
10-18-2017, 07:50 AM | #3 | |
10-18-2017, 08:46 AM | #4 |
Plug the hole in your transmission yoke and you can throw the sleeve away. It just keeps transmission fluid from going down the splines and dripping from the weep hole in the yoke.
