Old 10-06-2020, 02:11 PM   #101
msg
Re: 350 GM Crate Motor questions for a 66 C10
Originally Posted by geezer#99 View Post
By the time this is all done you’re gonna be the go to guy to answer questions on engine installs!
Be glad to, scary thought though coming from me.
You all have helped me greatly and I appreciate it!!!!
Like this question, the 2 red plugs on the valve covers..does it matter which gets the PCV valve? I guess one side gets PCV and the or a breather cap?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 10-06-2020, 04:28 PM   #102
msg
pics
Old 10-06-2020, 04:47 PM   #103
geezer#99
geezer#99's Avatar
Drivers side usually had the pcv. Rear of passenger side for breather.
You got a cap on one of them for adding oil?
geezer#99 is online now   Reply With Quote
Old 10-06-2020, 05:01 PM   #104
msg
Yep oil cap is up front on drivers side. Is there a recommended PCV and airbreather part to use on this engine?
Old 10-06-2020, 05:27 PM   #105
geezer#99
geezer#99's Avatar
That I don’t know.
Any instructions in your manual or info with the motor.
If not then stock stuff should work.
Old 11-12-2020, 11:58 PM   #106
msg
Pretty sure this is right but isnt this HEI diagram and the firing order the same as a the L31?
Im trying to get my distributor and wires worked out to see how things fit. Once the fit is right I need to I think remove the driver side valve cover and rotate the engine to find top dead center before locking down the distributor.
I watched this video and think this is the right way to get it set up on my engine?
https://www.youtube.com/watch?v=O4WRL513Gx4
Old 11-17-2020, 11:29 AM   #107
xbanone
xbanone's Avatar
On the quadrajet, I would at the very least do a light rebuild with a new accelerator pump and gasket kit. You can get as basic or as complicated as you want with the rebuilds. The ethanol fuel really does a number on those old pumps and the newer pumps are made from a better material. I use cliffshighperformance.com for my rebuilds. Check out their SR rebuild kit.
1976 K15 Short/Step
1981 C10 short/wide
1994 K1500 ECSB
xbanone is offline   Reply With Quote
