Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 10-01-2020, 04:26 PM   #1
Zippi
Zippi's Avatar
*Hood Is Warped*
My hood on my 49 on the drivers side is fine but the passengers side has a small warp. Seems pretty flimsy at the warp. What are my options to get it like the drivers side?
If you can't fix it with duct tape, it's an electrical problem.
1949 5 Window 3100
https://zippi6.wixsite.com/adtruck
Zippi is offline   Reply With Quote
Old 10-01-2020, 06:41 PM   #2
nsb29
nsb29's Avatar
Re: *Hood Is Warped*
That’s tuff being painted is there braces under there that could be bent
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 10-02-2020, 03:08 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Nsb..the rear hood brace runs from hinge to hinge...from the back of the brace there is about 3in off hood hanging past it..and around 8in hanging past down at the hinge..
I would be scared to do much with all that shiny paint on it...
Does it look like its "bent" up any at all...or does it look reasonably flat?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 10-02-2020, 06:46 PM   #4
Zippi
Zippi's Avatar
It looks flat. but there is more gap there than what is on the drivers side. I can push down on the hood at the brace and the warped area goes down. Any way to pull that down to the brace?
1949 5 Window 3100
Old 10-02-2020, 08:12 PM   #5
nsb29
nsb29's Avatar
So you’re saying there is a gap between the brace and the skin if that’s the case I would consider an adhesive but sum thing less permanent than panel adhesive maybe silicone
Old 10-02-2020, 09:38 PM   #6
JJH Jimmy
JJH Jimmy's Avatar
Maybe cut a couple notches in the brace along the high area and use panel adhesive to attach some 1/4” bolts to the hood skin and then use washers and nuts to pull the skin to the brace? It will be Kind of noticeable when you open the hood though.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 10-05-2020, 09:04 AM   #7
Zippi
Zippi's Avatar
Here are a couple pic from the side. Thinking now I'll just leave it alone.
1949 5 Window 3100
Old 10-05-2020, 06:03 PM   #8
nsb29
nsb29's Avatar
Probably not a bad idea
Old 10-05-2020, 06:41 PM   #9
mongocanfly
Post Whore
Still 100x better than it was new..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-06-2020, 12:23 AM   #10
PDW HOTRODS
PDW HOTRODS's Avatar
Find an assembly manual, there is adjustment in the middle of that rear brace. The manual tells how to adjust. Basically you add a washer or take away where the two back braces bolt together. You have the rubber mounted to the cowl for the hood to sit on, you could try to shim it up a little either side of the high spot or on the other side of the hood. You could test first by adding rolled up shop towel in a few spots first to see if it would help.
PDW HOTRODS is offline   Reply With Quote
Old 10-06-2020, 06:45 AM   #11
Zippi
Zippi's Avatar
Thanks for the info guys.
1949 5 Window 3100
Old 10-06-2020, 04:55 PM   #12
oem4me
I have zero experience with your era truck, but your situation brings to mind some wisdom imparted to me about 40 years ago by my old body shop teacher.
This guy was a retired shop owner and lifetime body/paint man who had acquired a good many specialty tools over the years.
I was attempting to align a hood on a 64 Corvair which had fitment issues similar to yours, when he suggested I use one of his favorite tools for fine tuning various panels. He stepped out back of the shop for a second and returned with a short 2x4 in his hand. Without hesitation, he placed the piece of lumber on top of the front fender and proceeded to bring the hood down, trapping the lumber between the two. After a few heaves on the opposite corner of the hood, he raised the lid, tossed the 2x4, and shut it completely revealing a perfect fit. Ha!
Old 10-06-2020, 05:56 PM   #13
nsb29
nsb29's Avatar
I have seen a few doors adjusted that way works every time
