Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-16-2020, 08:21 PM   #1
Zippi
Zippi's Avatar
*How To Install A Relay*
First let me say I know nothing about the electrical portion of a car. I have installed a new set of bucket seats in my 49 and the drivers seat is electric. I have put power to it and it all works fine. I'm told it needs to be connected to a 20 amp relay. I will have one + wire and one - wire coming from my seat. Can someone tell me where these two wires will connect to the relay and where the power will connect. I've looked at wiring diagrams its Greek to me.
If you can't fix it with duct tape, it's an electrical problem.
1949 5 Window 3100
Zippi is online now   Reply With Quote
Old 01-16-2020, 10:35 PM   #2
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: *How To Install A Relay*
Ok here you go.
Your relay should be marked with the same numbers as my drawing.
1-You will need a wire straight off the fuse panel are battery that has a good 12 volts on it all the time to plug in to the #30 terminal of the relay with a 25-30 amp fuse in line.
2- Then the + wire you have from the seat will go to terminal #87.
3- The - wire from the seat can go straight to the frame.
4- The relay terminal #85 will need a ground as well. You will need one relay for each seat.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is online now   Reply With Quote
Old 01-16-2020, 11:36 PM   #3
lutronjim
Why is a relay needed? Why not just a fuse?
lutronjim is offline   Reply With Quote
Old 01-17-2020, 05:11 AM   #4
Richard
If installed properly the relay will allow power to flow directly from the power source to the device. The switch just activates the relay. In your case ignition turned on will power relay (86). Power to relay from battery (30) should be direct as possible to battery meaning not through switches or other devices. The information provided by the previous post is good. While I disagree a standard 30 amp Bosch relay should be fine for both seats provided adequate wire size is used.
Richard
Old 01-17-2020, 01:22 PM   #5
The Rocknrod
MCPO USN Ret.
The Rocknrod's Avatar
Relays are used in circuits to reduce the current that flows through the primary control switch (like a headlight switch). So your using relatively low current to control the relay (for the headlights), instead of running high amps thru the light switch.
A smaller switch or sensor can be used to turn a much higher capacity relay on and off.
Old 01-17-2020, 06:21 PM   #6
Zippi
Zippi's Avatar
Thanks for the info guys. Only the drivers seat is power so do I still need a 25-30 amp inline fuse? What amp relay do I need? Same size as the inline fuse?
1949 5 Window 3100
Old 01-17-2020, 08:04 PM   #7
Zippi
Zippi's Avatar
I have a second smaller fuse block with an open spot. I'm not sure what the amp rating is on this block. Can I run a wire from this fuse block to #30 terminal?
1949 5 Window 3100
Old 01-17-2020, 11:22 PM   #8
Andy4639
Orignal Goof member
Andy4639's Avatar
Talking Re: *How To Install A Relay*
The relay should be a 30/40 amp and the fuse should be at least 30 amp.
It's like your head lights. You want as much power to get to the seat motor as possible.
No you don't have to put 2 relays in for both seats but if some point 2 people hit the seat switches at the same time then you will know why I suggested 2 relays.
Old 01-18-2020, 08:56 AM   #9
Zippi
Zippi's Avatar
Thanks for the help.
1949 5 Window 3100
Old 01-18-2020, 10:46 AM   #10
Andy4639
Orignal Goof member
Andy4639's Avatar
Your welcome sir!
Old 01-18-2020, 10:27 PM   #11
lutronjim
If The Rocknrod is answering my question of why a relay, all the cars that I have had didn't have any switch to power the seats - not even ignition. They were, I guess, fused directly from battery. You could open door and move seat.
If the little woman had the seat under the steering wheel and you wanted to get in, you might have trouble reaching the switch or ignition.
Old 01-18-2020, 10:43 PM   #12
Andy4639
Orignal Goof member
Andy4639's Avatar
It had to be switched from some place are the seat wouldn't move.
You said your self the switch had to be pushed once you open the door!
Copyright ©2000 - 2020, vBulletin Solutions Inc.
