Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 01-27-2011, 07:47 PM   #26
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Re: Anyone interested in a schrader/bag kit?
You would most likely want to use the brackets below for mounting on the leaf springs. And we could set it up to be one schrader valve split to both bags. Would probably cost about $15 more that way because of the extra fittings and air line.
AIRBAGPARTS.COM
AVS
jason@avsontheweb.com
559-486-5444 ext 114
MANUFACTURERS OF
Shave Door Kits
Switchboxes
LED Tail Light Kits
Bear Claw Latches
And Much More....
PROUD DISTRIBUTORS OF
AccuAir
Air Zenith
Belltech
Choppin' Block
McGaughy's
Porterbuilt Street Rods
Viair
And Many More....
AVS_JASON is offline   Reply With Quote
Old 01-28-2011, 04:22 AM   #27
franky69c10
chevy runs deep
franky69c10's Avatar
Hoe much 4 the front kit shipped 2 PHX AZ 85017
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 01-28-2011, 09:39 AM   #28
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Originally Posted by coater View Post
Can I run a line to both rear bags and use 1 valve under bumper to air both bags at 1 time? These will be used to level out when towing.
In my opinion, I wouldn't run just one line to both bags, it would not be good for load leveling, more weight on once side would try to push the air from that side to the other, further throwing off balance, same goes for going around a turn. I have helper bags on the back of our 95 Dodge Cummins dump truck, and the shraders are just run out and attached at the bottom of the bumper on either side.
You could run check valves between the two bags to keep air from transferring between them, but then you would have to add another shrader or some time of valve to release the air, which would not be hard to do at all either, just not worth it to me.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 01-28-2011, 10:47 AM   #29
coater
Thank You for that info! I'm an idiot when it comes to bags. Never used them. I definitly don't want the air to transfer. But was hoping for the ease of inflation and deflation.
coater is offline   Reply With Quote
Old 01-28-2011, 12:27 PM   #30
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
$23.50 for shipping to you.
AIRBAGPARTS.COM
AVS
MANUFACTURERS OF
Shave Door Kits
Switchboxes
LED Tail Light Kits
Bear Claw Latches
And Much More....
AccuAir
Air Zenith
Belltech
Choppin' Block
McGaughy's
Viair
And Many More....
Old 01-28-2011, 01:14 PM   #31
Gobbles
Gobbles's Avatar
I would be interested in the rear set up, not sure what rear brackets to use? Never used bags before. They will be going on an '85 with a 5 or 7" rear drop w/c-notch. Can I run a line to both rear bags and use 1 valve under bumper to air both bags at 1 time? These will be used to level out when towing. My zip is 31763.
Thank You!
I would not reccommend this unless you have the bags lined up exactly the same. I found that my hangers sat differently due to the off centered weight from my diff, this caused the bags to sit at slightly different angles. Which then forced different pressures to have the same ride height. My $0.02
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 01-28-2011, 01:58 PM   #32
SCOTI
SCOTI's Avatar
Definitely run one schrader per bag if going that route. The schrader valves can be placed side by side to ease filling/purging of air. I did my 68 beater like that w/both fittings behind the flip up license plate.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 01-28-2011, 02:22 PM   #33
jimmydean
jimmydean's Avatar
My truck has shraders mounted on either side of the frame for some helper bags in the middle of the springs. I won't be running shraders, but I thought it was a pretty cool setup for being as old as the truck.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-28-2011, 02:57 PM   #34
SCOTI
SCOTI's Avatar
Cheap & effective. My 68 was done this way for almost 2yrs of daily use before I swapped in a still basic tank/comp set-up. It worked so well I did a schrader set-up in the 74 as an AOL type of kit. Since the 74 already had holes drilled into the bed floor in front of each wheel tub, that's were I put the schraders on it. Still easy enough to get to them despite one being on each side.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-29-2011, 12:29 AM   #35
coater
I can understand that! That's the route I need to go then. I like the idea that SCOTTI has with the 2 valves somewhere easy to get to. Thanks Guy's!
Old 01-29-2011, 04:21 AM   #36
52 choptop
52 choptop's Avatar
Absolutely! How can you put a price on stopping your wife from saying "You're dragging your front bumper again"? Is it alright if I email you direct? I have parts (tank, comp), but need some advice. let me know, thanks. Eric
52 choptop is offline   Reply With Quote
Old 01-29-2011, 06:20 AM   #37
jmcdaniel
jmcdaniel's Avatar
Question Re: Anyone interested in a schrader/bag kit?
I've got a 70 1/2 ton suburban and i would be changing over to dropped spindles and disc brakes, what else would i need with this kit to make it complete. I am not looking for anything fancy but i do want this to be a very functional kit since i am making this burban into a DD. I am very new to the airbag world and i am debating on whether or not to do a static or bag drop? help me out.
1963 C-10 custom cab on a 70 swb leaf spring frame, 283/3spd rat rod
1986 crewcab 3+3 camper special 454/400 pig rig (soon to be bagged)
jmcdaniel is offline   Reply With Quote
Old 01-29-2011, 01:28 PM   #38
SCOTI
SCOTI's Avatar
How low are you wanting to go?
Personally, I wouldn't do a schrader set-up on the front as anything more than a temporary thing; the rear isn't quite as critical on tire wear. The pressures need to remain @ a determined amount to maintain alignment (something important for a DD). When only using schraders, there's no way to verify that pressure is being maintained. Of cource wouldn't really have to do this daily, but it would be like checking your tire pressures every day before leaving the house.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2011, 12:08 AM   #39
royo
royo's Avatar
Do you have a different valve. I dont know what its called. is it a paddle valve Ive seen them next to air gauge,s on a panel?
nickle and dime
royo is offline   Reply With Quote
Old 01-30-2011, 12:34 AM   #40
jmcdaniel
jmcdaniel's Avatar
I never thought about all of those things. thx. I'll just probably go with a static drop then and be done with it.
Old 01-30-2011, 02:26 AM   #41
SCOTI
SCOTI's Avatar
That's how I did my 68. Static 5-6" drop up front & bags in place of the coils in the rear.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2011, 04:20 PM   #42
52chevy
52chevy's Avatar
This is awesome, one of my coworkers has been looking for something like this without spending big cash. How much would shipping be to 67207?
52chevy is offline   Reply With Quote
Old 01-30-2011, 04:58 PM   #43
Mkcustums
Mkcustums's Avatar
They are "manual" valves.
Mkcustums is offline   Reply With Quote
Old 01-30-2011, 08:09 PM   #44
royo
royo's Avatar
WOW thats it right there Thanks I like the one with the 4 things on it lol
nickle and dime
Old 02-02-2011, 11:18 AM   #45
coater
AVS JASON.......What it cost me to go this route with the brackets you recommended in your post for an '85 shipped to 31763? going to have a 5 or 6" drop in the rear.
Coater
Old 02-02-2011, 12:10 PM   #46
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Coater
PM sent
AIRBAGPARTS.COM
AVS
MANUFACTURERS OF
Shave Door Kits
Switchboxes
LED Tail Light Kits
Bear Claw Latches
And Much More....
AccuAir
Air Zenith
Belltech
Choppin' Block
McGaughy's
Viair
And Many More....
Old 02-02-2011, 12:30 PM   #47
hotrodhomi
hotrodhomi's Avatar
Jason, do you have these valves?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-02-2011, 01:05 PM   #48
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
I have the manual valve like in the pic below.
AIRBAGPARTS.COM
AVS
MANUFACTURERS OF
Shave Door Kits
Switchboxes
LED Tail Light Kits
Bear Claw Latches
And Much More....
AccuAir
Air Zenith
Belltech
Choppin' Block
McGaughy's
Viair
And Many More....
Old 02-02-2011, 01:20 PM   #49
hotrodhomi
hotrodhomi's Avatar
Please post or send me a link. I can't find in on your website.
'66 impala ht
Old 02-02-2011, 01:32 PM   #50
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
They are actually not on our website. But I have them here in stock. They run $30 each.
AIRBAGPARTS.COM
AVS
MANUFACTURERS OF
Shave Door Kits
Switchboxes
LED Tail Light Kits
Bear Claw Latches
And Much More....
AccuAir
Air Zenith
Belltech
Choppin' Block
McGaughy's
Viair
And Many More....
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
