Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 02-05-2016, 09:29 AM   #1
Pro Performance
Pro Performance's Avatar
New Product! Aluminum Air Bag Spacer
NEW PRODUCT!
We have recently added another product to our line up. These air bag spacers for the F9000 Firestone sleeve bag will allow you to run less bag pressure at ride height. This is ideal when you are running a shorter tire than your rear suspension is setup for. Or, if you just want a smoother ride, then you can add these spacers under your sleeve bags as well.
For example:
If your rear kit is designed to lay out on a 30" tall tire, but are running a 28" tall tire, you would have to inflate the bag more to make up for that 1" lower ride height it would create. When doing that, it means more pressure.
With the bag spacer, you can now lift up to the desired ride height, and use less pressure for a smoother ride as it was intended to be like. If you decide to go to a larger tire in the future, just remove the spacer.
I recently put these in my truck for the same reason mentioned above. It really helped with ride, and have been running them since.
We have had request to make them for the larger D2600 bags. If demand is enough, we will do it... so let us know.
Aluminum Air Bag Spacer: $49
AZProPerformance.com | 480-420-8175
Contact Us About Our Monthly Specials
Wheels / Tires / Suspension / Brakes / Air Suspension Components
Choppin' Block - AccuAir - McGaughys - Raceline Wheels - Hot Rods by Boyd - American Racing - Schott - Boze - Wilwood - Baer & More!
Pro Performance is offline   Reply With Quote
Old 02-08-2016, 12:58 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: New Product! Aluminum Air Bag Spacer
Sweet, nice product! It looks like these could be used to adjust coil spring rears also. Either to level out or raise back up. I would offer them in increments of .25", .5", 1"....... Just a suggestion as I think there is a market for this.... . I only ask that you send my 10% of the profit, .
Rob - http://instagram.com/hart_rod
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
FOR SALE: DBW pedal bracket, Pedal adapter for LS trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=651123
FOR SALE: ChubTubz, Rear tubs for slammed trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=675754
FOR SALE: Hood Brackets, Bolt in hood brackets! http://67-72chevytrucks.com/vboard/s...d.php?t=679945
1969 SuperBurb - 5.3/Magnacharger..http://67-72chevytrucks.com/vboard/s...d.php?t=200387
1968 Farm truck: LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
1968 SWB - SHIFTED: PB Xtreme DM/LS1/Dakota Digital/AccuAir/Vintage Air/...http://67-72chevytrucks.com/vboard/s...d.php?t=551258
1948 5 Window Chevy http://67-72chevytrucks.com/vboard/s...=122164&page=3
FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Hart_Rod is offline   Reply With Quote
Old 02-08-2016, 07:30 PM   #3
Pro Performance
Didn't think of it as a coil spacer, but yes, that could work too. Good looking out!
Do you take I.O.U.'s?
Old 02-09-2016, 09:24 AM   #4
Hart_Rod
Hart_Rod's Avatar
Not normally, but from you, OK......
Copyright ©2000 - 2019, vBulletin Solutions Inc.
