Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 08-06-2012, 04:54 PM   #1
PBFAB.COM
PBFAB.COM's Avatar
Porterbuilt Forward Arm Series - Sale
We're proud to introduce our new Forward Arm Series control arms this month with an exclusive sale.
Description:
Porterbuilt new Forward Arm Series tubular control arms were designed to help center the front wheels in the wheel opening on trucks using factory cross-member configurations, or chassis that have been Z'd and are still using a factory cross-member.
They're built using the same thick-wall DOM tubing and CNC cut 3/16 pickeled plate steel as all our other arms. All bushing pivot tubes and ball joint cups are TIG welded. We also use a machined delrin bushing to minimize deflection;eliminate squeaks associated with polyurethane; and to increase bushing life.
- Centered front wheels.
- Increased caster gains.
- Available for air spring and coil spring applications.
- Standard or narrowed widths.
- Will NOT work on Dropmembers. Strictly designed for stock cross-member applications.
- Retail prices start at 1,049.00 for a complete set of Forward Arms.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 08-06-2012, 06:22 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Porterbuilt Forward Arm Series - Sale
Will these work with factory springs?
Rob - http://instagram.com/hart_rod
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
FOR SALE: DBW pedal bracket, Pedal adapter for LS trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=651123
FOR SALE: ChubTubz, Rear tubs for slammed trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=675754
FOR SALE: Hood Brackets, Bolt in hood brackets! http://67-72chevytrucks.com/vboard/s...d.php?t=679945
1969 SuperBurb - 5.3/Magnacharger..http://67-72chevytrucks.com/vboard/s...d.php?t=200387
1968 Farm truck: LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
1968 SWB - SHIFTED: PB Xtreme DM/LS1/Dakota Digital/AccuAir/Vintage Air/...http://67-72chevytrucks.com/vboard/s...d.php?t=551258
1948 5 Window Chevy http://67-72chevytrucks.com/vboard/s...=122164&page=3
FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Hart_Rod is offline   Reply With Quote
Old 08-06-2012, 06:48 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
Yes sir!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-06-2012, 07:15 PM   #4
Hart_Rod
Hart_Rod's Avatar
How much will the truck be lowered with a factory spring?
Old 08-07-2012, 07:52 AM   #5
lolife99
Old Member
lolife99's Avatar
Very cool product!
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 08-07-2012, 08:50 AM   #6
Gus350
68 C 10
Gus350's Avatar
Does the narrowed widths give a static dropped truck lets say 5 inch drop a better turning radius? Or does this just tuck the wheels more.
Thanks Kevin
PS Im not liking you guys at PB to well right now your taking all my money lol
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 08-07-2012, 09:12 AM   #7
PBFAB.COM
PBFAB.COM's Avatar
The truck we originally fit these on remained at the same height as before. The lower plate that the spring sets on is at the same height as the factory arm.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-07-2012, 09:15 AM   #8
PBFAB.COM
PBFAB.COM's Avatar
Thanks Kevin
The narrowed trac width will allow for more clearance at the lowered heights, not necessarily more turning radius.
If the steering is limited by tire clearance issues, and not being limited by the steering components themselves, the narrowed arms could be beneficial.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-07-2012, 09:43 AM   #9
Hart_Rod
Hart_Rod's Avatar
So if I'm understanding this correctly (I'm a little slow, ), if I have 2" drop springs, 2.5" dropped spindles and factory A-arms, my truck should remain at the same height after I install your PFAs?
R/
Old 08-07-2012, 10:16 AM   #10
PBFAB.COM
PBFAB.COM's Avatar
R/
It should remain at the same height.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-07-2012, 12:12 PM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
So, I can have my arms narrowed 1" AND forward 1", or must I choose one or the other?
gringoloco is offline   Reply With Quote
Old 08-07-2012, 12:37 PM   #12
PBFAB.COM
PBFAB.COM's Avatar
You can have it both ways.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-07-2012, 03:24 PM   #13
Dinos63
chevy only
Dinos63's Avatar
nate these arms worked killer on my dually thanks again
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 08-07-2012, 10:24 PM   #14
Dinos63
chevy only
Dinos63's Avatar
pic
Old 08-07-2012, 10:59 PM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
I see you offer lowers only- advantages/disadvantages/differences between your tube uppers and stockers when combined with the 1" forward lowers?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
Old 08-08-2012, 10:41 AM   #16
PBFAB.COM
PBFAB.COM's Avatar
The reason we offer the lowers by themselves, is due to the fact that they work well with the factory upper. You get considerable castor gain but don't have to fork out all the cash for a complete set. There are a few advantages of going with our tubular uppers, but in this case it wouldn't be a necessity.
This is a great option for those not looking to break the bank, yet get some considerable performance gains with an easy bolt-on.
However, if one decided to go with the forward and narrowed option, the uppers and lowers must be purchased as a set.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-08-2012, 10:57 AM   #17
gringoloco
A guy with a truck
gringoloco's Avatar
Awesome, thanks! Few more Qs:
- How much caster could one expect to dial in with lowers only?
- I assume these will require a PB sway bar?
- Are there any available provisions for a bump stop?
- Are the front wheels still centered with lowers only?
Old 08-08-2012, 11:19 AM   #18
Bennett68C10
Bennett68C10's Avatar
I have these tubular arms on mine but with bags. Very Very nice piece. I did have to switch to a Porterbuilt sway bar to work with the arms. I highly recommend these arms to anybody who is looking into a set of tubular arms for their trucks especially since these can be made for either coils or bags. Some Pics of mine.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-08-2012, 07:05 PM   #19
Fattback
Fattback's Avatar
Bennett - What spindles you running?
Rob
Fattback is offline   Reply With Quote
Old 08-09-2012, 02:38 PM   #20
tubbedII
needs more $$$
tubbedII's Avatar
To piggy back on gringoloco's q's, how much more drop would you gain in a bagged set up over stock control arms?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 08-09-2012, 04:03 PM   #21
PBFAB.COM
PBFAB.COM's Avatar
-With the lowers only you will be able to get just over 7 degrees of caster.
-These will work with our sway bar, or the musclebar from Ridetech.
-We do not provide any provisions for a bumpstop.
-The wheels are closer to being centered, just not quite.
If lower bag mounting plate on the PB arms sits at the same height as the bottom of the coil spring cup on the factory arms. If switching from the factory arm with a bag plate or bag cup, you will gain additional drop with these arms. We have seen over an inch of additional drop.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-11-2012, 02:56 PM   #22
pedro6371
hi nate i have couple ??? how much are deliver to 91340 and how much it narrow the track thx
pedro6371 is offline   Reply With Quote
Old 08-16-2012, 10:45 AM   #23
buckstoy
Could I get a set of these to run with a regular spring setup then switch to bags later on, or are there two different lower a-arms for coil and airbag?
buckstoy is offline   Reply With Quote
Old 08-16-2012, 11:13 AM   #24
PBFAB.COM
PBFAB.COM's Avatar
The arms are identical on the bag set-up and the coil spring set-up. The difference is that we sell a billet spring retainer that bolts to the lower arm and locates the coil spring. It's as easy as unbolting it to switch to an air bag.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-24-2012, 03:12 PM   #25
rmvlt1100
rmvlt1100's Avatar
Description:
Porter Built:
Can you send me a quote on a complete set with shipping. I have a 1965 C-10 with air bags. Shipping is to Crest Hill, IL 60403
Thanks,
Robert
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
