Old 04-06-2009, 07:17 PM   #1
russgt
russgt's Avatar
Blazer floor question
What is the thick guage bracket called that is underneath the floorpan and follows the hump from under the seat to the higher part of the floor in the back? The rocker connects to it and there are three bolts that hold it in place. I need to find one for the drivers side of my 76 and do not know what it is called.
russgt is offline   Reply With Quote
Old 04-07-2009, 08:54 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Blazer floor question
I think I know what your talking about, but a pic would help so we can get it right the first time..
tvblazer78 is offline   Reply With Quote
Old 04-07-2009, 07:11 PM   #3
russgt
russgt's Avatar
here ya go
Old 04-16-2009, 04:34 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
That is part of the rocker box. It is not reproduced.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-22-2009, 05:19 PM   #5
russgt
russgt's Avatar
Ok, we ended up fabing some up, but you'd think that would be a crash part.
Old 04-23-2009, 06:39 PM   #6
tvblazer78
Low & Fast!
tvblazer78's Avatar
Cool happy that you got it to work and yeas someone needs to start making that.
Old 04-23-2009, 06:57 PM   #7
Captkaos
Captkaos's Avatar
The reason they don't is probably because it's a 3 year only piece. I have a set I pulled off a fulltop, just haven't called to aske about it yet.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-27-2009, 09:40 PM   #8
russgt
russgt's Avatar
What were the 3 years? I know that 76 is one of them so I am guessing 77 and 78? Here are some pics of what we did.
Old 04-27-2009, 09:47 PM   #9
russgt
russgt's Avatar
a few more
Old 04-29-2009, 09:28 PM   #10
Captkaos
Captkaos's Avatar
The rocker boxes were 73-75 with full removable tops.
Is the long narrow piece the front or rear?
This is the piece that will go under the front portion:
http://store.73-87chevytrucks.com/me...tegory_Code=C1
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-30-2009, 08:00 AM   #11
tvblazer78
Low & Fast!
tvblazer78's Avatar
Nice work man!!
Old 04-30-2009, 04:19 PM   #12
Red_69
Red_69's Avatar
Nice fab work!! Sweet job.
1986 Chevy 3/4 Ton 4X4
Red_69 is offline   Reply With Quote
Old 05-03-2009, 06:55 PM   #13
russgt
russgt's Avatar
if the rocker boxes are 73-75 only then why does my 76 have them? It is an all original, special order in may of 76 blazer.
Old 05-21-2009, 10:05 PM   #14
russgt
russgt's Avatar
That piece is for the front, the part you linked me to is not made the same as what I have.
Old 12-24-2016, 09:29 PM   #15
montrosepatriot
1976 and 77 was a continuation of the 73-75 full vert era - when the uniside assembly from the single cab truck (15615253, 14039174) (including the 3 pieces which make the rollbar (358643, 466723, 466724) and the outer/inner roof skins (355616 and 15610112) with the most hated rusted component (the drip rails 355679/355680) was phased in (after the full convertible production officially ended) the 73-75 cab floor pan with the rocker boxs was retained until the 1978 redesign where the cab floor was extended (which eliminated the rocker box assembly); the #s listed were abstracted from a GM parts catalog (most have been discontinued)
montrosepatriot is offline   Reply With Quote
Old 12-27-2016, 11:39 AM   #16
TooTall
Since the thread has been bumped
Are there any replacement options out there?
1984 K10, 8" lift on 35s
2011 Yukon XL | Bone stock
2013 Audi Q5
Old 12-27-2016, 05:16 PM   #17
montrosepatriot
after viewin the pix of the rocker box outer bracket - this should end up in the GMCPaul's product line since there r no reproduction sheetmetal which exists - an investment in a 3D printer 2 manufacture new tooling e.g. stamping dies (esp the full convertible upper windshield header which is available 4 the 69-72 but not 73-75) is feasible but R&D and licensing from GM can result in delays (also those from Auto Metal Direct should view this)
Old 12-27-2016, 10:18 PM   #18
montrosepatriot
this also using a 3D scanner 2 reverse engineer discontinued parts
