Old 03-18-2017, 02:31 PM   #1
hotrod1
56 - autocross
hotrod1's Avatar
Fuel & Brake line chassis tabs/clips
Building a new chassis. Need ideas for fuel (1/2") and brake line tabs or clips. Want to get them planned before welding in the cross-members. Seen anything cool?
hotrod1 is offline   Reply With Quote
Old 03-18-2017, 03:09 PM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: Fuel & Brake line chassis tabs/clips
Go to Summit and put "line clamp" in the search engine. Gives lots of options. I made my own using 1/2" aluminum bar stock and a drill press. Look like Billet Specialties but instead of tapping the aluminum, drilled through and used 10-24 nutserts in the frame so the clamp attached to the frame. A little time consuming but using different size drill bits, I could run any size and number of lines I wanted. Using the belt sander for contour, they didn't even look too bad.
Speedbumpauto is offline   Reply With Quote
Old 03-18-2017, 04:11 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
https://www.aa-mfg.com/ has pretty much any tab, gusset or bracket you may need.
Old 03-18-2017, 04:15 PM   #4
hotrod1
56 - autocross
hotrod1's Avatar
Thanks guys.
Found these on summit (speedbump credit). They Look interesting. http://www.notchead.com/line-clamps.html
Old 03-18-2017, 06:03 PM   #5
Kim57
Kim57's Avatar
You can see what I used in this pic.A little time consuming but turned out O.K.
I think mine are Kugel.
A link to similar ones at speedway.
http://www.speedwaymotors.com/Stainl...FUhufgod7MgMBw
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-19-2017, 11:36 PM   #6
BIGglaSS
BIGglaSS's Avatar
"P" clamps + rivnuts
BIGglaSS is offline   Reply With Quote
