11-15-2024, 09:46 PM | #1 |
Front hub - do I have a problem?
'66 C20. I'm seeing 2 lines inside the hub, diametrically opposite each other and each centered on the square notch. I THINK they are something from casting or machining, but want to be sure they're not cracks. Opinions?
11-15-2024, 11:23 PM | #2 |
Re: Front hub - do I have a problem?
Cast metals do not usually crack only partway, they don't really flex - they just crack completely. What does the other side look like? Any cracks on the machined surface?
You could hang it by a wrench or on a nail and give it a wee rap with a hammer - if it rings, it's likely fine, if it's more of a thud, it may actually be cracked.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
11-16-2024, 10:33 AM | #3 |
I believe you are right, the opposite side does not have any "crack" extending, and looking closely it appears there is actually a slight bevel or "V" shape to it. When I get to the other one I'll clean it up and look at that one closely, my bet it they will both have the same marks.
Thank you! |
