03-07-2011, 02:47 PM | #1 |
68 3/4 ton posi rear differential maxi tract R axle
Anyone think I would have any issues swapping this out with my current 12 bolt on my 72 3/4 ton c10?
http://67-72chevytrucks.com/vboard/s...d.php?t=450950 Looks like a good deal, but want to make sure I can use it before I commit to buy it. Thanks for the help. |
03-07-2011, 06:35 PM | #2 |
Re: 68 3/4 ton posi rear differential maxi tract R axle
C10 is a half ton
12 bolt is a half ton axle That axle is a Dana 60, and it should bolt into your half ton truck but it is 8 lug, not 6 lug like your 12 bolt.
Tim |
03-07-2011, 07:28 PM | #3 |
Thanks for the help. I was thinking 3/4 ton springs.
03-08-2011, 08:38 AM | #4 |
What do you actually have? If you have a coil spring truck then that rear will work,but you will have an 8-lug rear. Are you saying you have a '72 C/10 with 3/4t springs? In that case you have 5-lug wheels,right? If you have a C/20,which is a 3/4t truck,this axle is just for you.
03-08-2011, 11:43 AM | #5 |
It is a C10 with coil springs, and I was told from the previous owner he put in 3/4 springs in. He was hauling trailers around with it.
Yeah, the wheels are 5x5. Any disadvantages of running a 3/4 axle on a 1/2 ton truck besides having to get new wheels, and probably new brakes? Posi would be nice, but want to make sure I am going in the right direction. |
03-08-2011, 12:02 PM | #6 |
i've seen posted that some of those bigger rears that replacement brake drums aren't available. i'd check into that b4 buying
03-08-2011, 01:04 PM | #7 |
