Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-13-2017, 10:15 AM   #1
cjrolke
Wiring question 71 c10
On the diagrams I have seen, on a spare harness in another truck I have the dark green wires that run from the gauge cluster hook to the ignition switch then go to the fuse box. On my truck the green wire bypasses the ignition switch. Does not look like it has been cut and fixed anywhere. These seem to be for the temp gauge. What am I missing? Thanks
cjrolke is offline   Reply With Quote
Old 04-13-2017, 11:41 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Wiring question 71 c10
The green wires that go to the ignition switch are for the temp light to ground the sender wire, when the key is turned to the start position. this causes the light to come on as a test for the bulb. One of the green wires then continues on to the dash cluster to the number 5 pin on the cluster plug, to ground the light when the sender senses an overtemp on the engine.
When the factory installed the gauge cluster the light was no longer used and the two green wires were no longer used, instead one green wire was ran to the cluster plug and was moved to pin 6 on the plug. If your cluster has been converted then you are fine.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-13-2017, 12:53 PM   #3
cjrolke
thank you thank you thank you
that makes sense
I have been battling wiring in this truck for a little while and this helps a lot. when I got the truck the purple wire for the starter was actually hooked into that position. I had to move it to the correct location
thank you again
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
