Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-18-2019, 12:12 PM   #1
Orange Crate
Orange Crate's Avatar
Steel Wheel Paint
I had my steel wheels powder coated and that didn't work out too well (1st pic notice the bubbles in the gap) then I took the wheels to a body shop to get painted. They told me to have the center (inside when the tire is on) painted first, then put the tires on but don't set the bead, then they would paint the outside. I guess this is to avoid having the paint scratched off when installing the tires (if you don't do it this way). What has everybody else done? Can painted wheels stand up to having a tire installed after paint? 2nd pic is the wheels as is from the bone yard.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
Old 02-18-2019, 01:23 PM   #2
MARTINSR
MARTINSR's Avatar
Re: Steel Wheel Paint
First off, I would have put those powder coated wheels on the truck and drove it with a smile on my face, done deal!
But if you are now going to paint the wheels, putting the tires on and not beading them, is the trick of tricks when painting wheels. I did a LOT of them years ago doing restoration work on early Ford V8's. You cover the tire, tucking the paper down inside, you can paint around the edge nice, then unmask and fill the tire beading it and wham, looks like the tire was removed when you painted it, works like a charm.
But really just put those powder coated wheels on and enjoy the truck. I know I did that with my daily driver 59 Rambler. I saw that down there in the crack too, put them on, I drive it every day and enjoy it. Just as I typed that last sentence I leaned back in my chair to see it parked out in front of my house. LOL Yep, it puts a smile on my face even with the less than Grand National Car Show center arena rims on it.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 02-18-2019, 03:34 PM   #3
Orange Crate
Nope, not going on my truck. That picture is probably the best one but others were bubbled up worse than that. I had the powder shop re-sand blast that crap right back off. I'm not into making up excuses for someone else's work.
Old 02-18-2019, 03:58 PM   #4
sick472
sick472's Avatar
Any wheel type shows evidence that they have been to a typical tire shop and had tires put on. With that said, a good tire man (with concern for the classics and enough patience) can avoid the typical marring by taking his time and really lubing up the rim and tire prior to tire install (amomg other tricks of a picky tire service tech).
Of couse, paint type can be a factor to resisting any marks too, how well cured it is, how thick it was put on, and how well prepped the wheel was for adhesion are also factors.
With all that said..to avoid any possible marks...install the wheels off-bead for exterior painting as suggested and you have one tire install under your belt without concern.
He who is without oil shall throw the first rod. Compressions 8.7:1
sick472 is offline   Reply With Quote
Old 02-18-2019, 09:02 PM   #5
mongocanfly
What are they putting tires on with?..tire irons?....I can see you run the risk of scratching a painted wheel but most any modern tire store can put tires on without scratching them...the machine my tire man uses doesn't touch the rim except in the center
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
mongocanfly is online now   Reply With Quote
Old 02-18-2019, 09:25 PM   #6
Orange Crate
Thank you for the comment. This is why I am a member here, because I can get answers. I don't put tires on, I drop off my rims (or the vehicle) and I go get coffee, and when I come back the new tires are on magically. I think my next stop is to my local tire shop to see what the process is, thanks again, very helpful.
Old 02-18-2019, 11:41 PM   #7
MARTINSR
MARTINSR's Avatar
Yes, a newer tire machine is pretty magical for sure.
Brian
1948 Chevy pickup
Old 02-19-2019, 09:20 AM   #8
mongocanfly
I've painted my share of wheels....this area in the red circle is always hard to get paint into...hard to sandblast in there as well......
Mongo...aka Greg
Old 02-19-2019, 04:08 PM   #9
Keith Seymore
Keith Seymore's Avatar
Could a person run a little bit of color coordinated caulk in there?
I just had some trailer wheels powder coated in silver and noticed the same thing. I might try the caulk idea on them.
In any case I think the powder coat will be more durable than any kind of spray paint.
K
Chevrolet Flint Assembly
1979-1986
1986 - Feb 2019
Old 02-19-2019, 04:51 PM   #10
mongocanfly
I've used caulk before on things I've painted...it looks ok for a while but after it ages not so much...
Powder coat is far better than any paint...
Mongo...aka Greg
Old 02-19-2019, 08:37 PM   #11
MARTINSR
MARTINSR's Avatar
Yep, taped on each side, seam sealer applied with some pressure then un-tape, whamo. http://www.autobodystore.com/seamsealer.shtml
Brian
1948 Chevy pickup
Old 02-19-2019, 09:49 PM   #12
projectking
projectking's Avatar
Iíve see where they preheat the wheels before hitting that area or something(guy told me there was a trick)... and mine look fine in that area.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 02-20-2019, 04:03 PM   #13
Orange Crate
Did you powder coat or paint?
Old 02-20-2019, 04:57 PM   #14
projectking
I had some wheels powder coated.
67 Chevy C10 LWB
90 Mustang Gt
Old 02-20-2019, 06:36 PM   #15
Orange Crate
The powder shop I used tried a couple things, they actually coated them two times but it didn't seem to work either time. I talked to others and some powder coats work and some don't. I want the wheels to be as close to perfect as I can get them.
Old 02-24-2019, 05:14 PM   #16
theastronaut
theastronaut's Avatar
That's an annoying area to get right even when you're painting wheels. If you blast them sand gets trapped there and you have to dig it out with a razor blade. High build primer can fill in the gap, usually only in spots so that looks like garbage. I usually scrape and use folded sandpaper to get everything out so the gap is open and clean, then use a light epoxy to prime and seal the metal without bridging the gap. I like to use single stage urethane on wheels; it holds up well and won't scratch off if care is taken when mounting tires.
***Note for powdercoated wheels*** Always remove the coating under the lug nuts! Powdercoat is thicker than paint and if/when it chips out your wheels can come loose!
theastronaut is offline   Reply With Quote
Old 02-24-2019, 06:02 PM   #17
Keith Seymore
Thank you for pointing that out. That is something I had wondered about.
K
1979-1986
1986 - Feb 2019
Old 02-24-2019, 08:47 PM   #18
nsb29
nsb29's Avatar
You are so right it looks like sand was left in there to me I use Reduced epoxy and syringe to get it in the crack before painting if I make a mess Iíll clean it up this way I get protection down in that seemWithout bridging the gap I also believe in single stage I also hate powder coating if you get a chip rust will creep under it and then it will come off in sheets it is used in industry because there are no solvents and not regulated by the epa it is applied to bare metal you might as well put your paint directly to bare metal there is no difference itís a joke if you live in a wet climate I know someoneís going to disagree lol
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
Also A/C center duck for 65 Chevelle
3-D scanning and printing of rare and obsolete parts
nsb29 is offline   Reply With Quote
Old 02-24-2019, 11:54 PM   #19
franken
No one is going to notice the bubbles once the wheels are on the ground. After spending $250 for PC I'd drive it. I also had PC on wheels and in hindsight should have rattle canned them. I also told the tire dealer to not mar the finish and they did no damage.
They're on a Camaro and look so nice I can't put trim rings or centers on them so I'm a fool...
franken is offline   Reply With Quote
Old 02-25-2019, 10:25 AM   #20
MP&C
MP&C's Avatar
IMO I'd keep the powder on those.
For painted wheels, painted hardware, and the like, I've found too much paint build is as much a recipe for failure as anything. So for wheels I prefer epoxy, then acrylic enamel (if you're digging through old stuff in paint cabinet) or catalyzed urethane instead of a base-clear any day ..
Painted these Ranger wheels up for my car trailer. Paint was Centari Acrylic enamel, probably 35-40 years old in the can..
As far as the painters wanting to spray with tires mounted but not seated, they have likely had to touch up too many times and then have someone call their paint into question because the tire changer dropped something on the edge. Yes, it happens. When your painter can't control who does what at the next phase and he has an anal retentive nature bordering on OCD, he paints with tires mounted but not seated so someone doesn't hose up his work in 2 days time..
Robert
MP&C is offline   Reply With Quote
Old 02-25-2019, 12:33 PM   #21
Orange Crate
That isn't sand, it is bubbled up from the heat. The other wheels were worse than that one. I can definitely pass along all the tips here to whoever I choose to paint the rims. Keeping the PC isn't an option as I had them re-blast them clean after two attempts.
Old 02-25-2019, 01:10 PM   #22
MP&C
MP&C's Avatar
In my pictures above, during each coat the first thing sprayed was straight down into the crack.
Robert
Old 02-25-2019, 03:56 PM   #23
nsb29
nsb29's Avatar
Thatís the trickiest part get the paint in there but donít run it
Old 02-25-2019, 04:06 PM   #24
nsb29
nsb29's Avatar
Well I believe something was in that crack that caused your problem if not sand moisture solvents something Iím not a fan of powder coating but I have seen a lot wheels that have been powder coated that were just fine if youíre thinking that it got too hot there when you say it was the heat where those wheels are put together is the thickest part would seem as though it would be the coolest part good idea go to a good painter Too many suggestions though my T him off
Old 02-26-2019, 02:30 PM   #25
Orange Crate
Yes there was something in there they couldn't get out after two attempts. I meant the heat used for curing the powder coat. They sand blasted first, cleaned, air blasted whatever to get that area clean, then they powder coated. I went to look at them and said they were definitely not going on my truck the way they looked. They started over by blasting them clean again, re-coated them and they turned out looking the same, so I had them blasted clean and paid them for that work only (sand blasting). I really wasn't aware that steel rims were so much work.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
