Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-21-2019, 10:21 PM   #1
CG
BlahBlahBlah
Removing paint from small parts?
Is there some sort of paint remover available to the public that you could soak small parts in and get it down to bare metal. I'm thinking hubcaps, misc. small painted trim pieces, radio deletes ... stuff like that.
Old 03-22-2019, 12:01 AM   #2
MARTINSR
MARTINSR's Avatar
Re: Removing paint from small parts?
I end up stripping with the sand blaster on stuff like that. Paint remover some times, but most of the time at the very least finishing it off with the sand blaster.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 03-22-2019, 03:20 AM   #3
mongocanfly
yep..blast cabinet works great for smaller parts
im sure there USED to be some great liquid paint removers before the epa ruined everthing
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 03-22-2019, 10:04 AM   #4
MARTINSR
MARTINSR's Avatar
Now I don't have a sand blast cabinet, we are talking a bucket-o-sand kinda thing. Just blast out in the back yard. You can put up a little "cabinet" with a tarp over a table or something on top of concrete and blast under it then sweep up the sand and reuse.
I have something like this only smaller.
I also have a "Speed blaster" with the "Hot Spot" attachment allows you to sand blast small spots with virtually no sand flying out! A very valuable tool in my opinion.
Brian
1948 Chevy pickup
Old 03-22-2019, 11:48 PM   #5
oem4me
oem4me's Avatar
There's lots of brush-on paint removers available at home stores that will do small jobs easily. Plus you can buy in small quantities. Blasting is certainly the way to go for some stuff, but not everything. Removing painted details from polished trim pieces requires a chemical, not abrasion. Cleaning failing paint from emblems and such can sometimes be accomplished quickly with a shot of carb cleaner and a toothbrush.
Old 03-23-2019, 08:33 AM   #6
nsb29
nsb29's Avatar
Depending on the size of the part and the sandblaster you’re using is very easy to warp the parts something like a radio delet hubcaps Would be OK
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
Also A/C center duck for 65 Chevelle
3-D scanning and printing of rare and obsolete parts
nsb29 is offline   Reply With Quote
Old 03-23-2019, 01:32 PM   #7
Keith Seymore
Keith Seymore's Avatar
A mixture of hydrochloric acid and water works nicely on rusty steel parts. Throw them in a plastic bucket and check in on them every so often. Rinse when done and paint or oil right away.
Do not use for aluminum parts. They will dissolve.
K
Chevrolet Flint Assembly
1979-1986
1986 - Feb 2019
Old 03-23-2019, 02:18 PM   #8
MARTINSR
MARTINSR's Avatar
You are right to point that out, good catch! We are talking small parts, "hard" parts and small sheetmetal parts or things like floors and firewalls and stuff like that. But DO NOT sand blast large panels like hoods and doors as they can warp VERY EASILY and very badly.
Picture the sand as being millions of tiny hammers putting dents in the outer layer of metal!
Good thing to make that perfectly clear.
Brian
1948 Chevy pickup
Old 03-23-2019, 04:21 PM   #9
CG
BlahBlahBlah
There used to be places around here that you could have entire bodys dipped and they come out bare metal when it was only paint being removed. I believe they still have them in Oregon, I know some of the restoration shops use them.
I was thinking there must be a way to do small pieces at home. Im not talking rust removal, just a decent part that I want the paint stripped off of. I don't have a sand blast cabinet and wasn't wanting to purchase anything to blast.
Ill check the home stores. I have heard of something called aircraft stripper that people brush on and then scrape off. I wonder if I can just put some in a metal container and drop the parts in that I want the paint to come off of? As you can tell I have pretty much no idea what Im talking about haha!
Old 03-23-2019, 07:06 PM   #10
oem4me
oem4me's Avatar
There's a guy out here that sells this paint remover and a bunch of other metal cleaning/conditioning products at local swap meets. I guess it's all available online too. I can vouch for the effectiveness of the stripper, metal prep, and rust remover, as they all work well. The paint stripper is sprayed on via spray bottle, so it's quite convenient. http://www.blulightning.com/aircraft...mover-1-gallon
Old 03-24-2019, 09:53 AM   #11
CG
BlahBlahBlah
The website is a little slim in the complete info department. Ill give them a shout next week sometime. Thanks for the heads up!
Old 03-25-2019, 07:23 AM   #12
nsb29
nsb29's Avatar
The simplest and easiest thing to do is go to your local hardware store and buy a gallon of paint remover brush it on i’m sure you could put it in a plastic bucket and soke your part in it but I think it would be a waste of material and then you have contaminated the whole thing
Old 03-25-2019, 08:50 AM   #13
Keith Seymore
See post 7 above.
The acid is available at pool stores or Home Depot and it’s sold under the name of “Muratic Acid”.
The ratio is around 7:1 or 10:1 parts water vs acid.
K
1979-1986
1986 - Feb 2019
Old 03-25-2019, 07:56 PM   #14
CG
BlahBlahBlah
Originally Posted by Keith Seymore View Post
See post 7 above.
K
Oh sorry, I thought this was a formula for removing rust and scale, not for paint removal ... Thanks!
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
