Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-23-2019, 10:43 PM   #1
Mike's money pit
Removing surface rust to repaint
Hi guys, I tried to search for old threads dealing with my questions but saw lots of different answers due to the variety of situations. I am in the process of buying this 1988 C1500. The silver paint on the roof is thin or missing, and the roof has a bit of surface rust. Id like to sand the roof with a DA sander and 80 or 120 grit (if that is best for removing the paint and rust) and then repaint. What is the proper method to get the metal from its current condition to ready for epoxy?
Thank you,
Mike
Mike's money pit is offline   Reply With Quote
Old 03-24-2019, 12:07 AM   #2
mongocanfly
Re: Removing surface rust to repaint
hit it with the da like you planned...don't overheat it or put to much pressure on it..let the sandpaper do the work for you...should be good
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 03-24-2019, 01:01 AM   #3
Foot Stomper
Foot Stomper's Avatar
Don't remove any paint that's tightly adhered as there's no benefit, only harm.
Remove loose, flaking or otherwise unhealthy paint with da.
Solvent wipe and apply epoxy primer to bare steel.
Little specs of rust in the steel can be primed over with epoxy. Just make sure you have it sanded enough that you can't scrape any rust off.
Prep the rest of the roof, high build primer, then paint it.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 03-24-2019, 02:19 PM   #4
Mike's money pit
Thank you for the replies. So my plan will be DA on the rusty areas specifically but I will only sand enough to get most of the rust. If there are a tiny pits I will leave that. The rest of the paint on the roof will only get sanded off if it is loose. I will make sure to scuff the whole roof with the DA. Then I will tape off and apply epoxy.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
